03-24-2023, 04:52 PM | #1 |
Stock rear bump stop clearance?
Anyone know approx. what the factory rear bump stop clearance was on a 68 C10?
I'm trying to figure out if mine has been lowered some already. I have about 3" of clearance now. Last edited by samert111; 03-24-2023 at 05:06 PM. |
03-24-2023, 06:11 PM | #2 |
Re: Stock rear bump stop clearance?
I'm thinking stock bump stop clearance is in the 6" - 7" range since my truck has 6" drop springs and I had less than 1" of bump stop clearance before I installed shorter bump stops. Maybe the drawing below could be used to figure it out. You could measure your tailgate height (stock 27-1/4") and subtract the diff clearance (stock 7-1/2") to see how close you are to 19-3/4". These measurements won't work well if your truck has a lot of rake (lower in the front).
03-24-2023, 11:13 PM | #3 | |
If your estimate of 6-7 inches as stock is correct, then mine has already been dropped several inches but based off the tire clearance to wheel opening on the front compared to your image I'm not so sure now. |
03-24-2023, 11:49 PM | #4 |
I don't know what to think about that drawing from the brochure. My tailgate is 23-3/4" high with a 6" drop. On top of that, my tires are smaller in diameter than the factory tires. It doesn't add up. Photos from the sales brochure make the space between the tires and fender wells look much larger than in that drawing.
03-26-2023, 12:59 AM | #5 | |
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
03-26-2023, 07:29 AM | #6 | |
This first picture shows 7 1/2" between the top of the trailing arm and the bottom of the frame rail using 5" drop springs . The second picture shows I used the earlier 63-66 ? lower shock mounts ,It's a better mount using double shear vs 67-72 single shear lower mount . and upper shock relocators .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-11-2023, 08:09 PM | #7 | |
To correct the rear shock angle I'm looking at relocating the rear shock with either the Tin Works or No limit kit that moves the rear shocks to behind the rear diff and the outside of the frame rail. |
04-17-2023, 07:24 PM | #8 |
So after much searching for upper and lower shock mounts for my rear shocks to correct to extreme shock angle caused by the approx. 4" rear drop, I came up with modifying a set of Summit Racing rear shock relocation brackets ($55) to mount the shocks outside the frame rail and behind the rear diff. The upper mount was modified the most and now is mounted vertically bolted to the frame rail. The bottom mounts were reversed and switched sides to move the lower mount point to the inside of the trailing arms and behind the diff. The shocks are sitting vertical to the trailing arm mounting pad.
The trailing arms are a mess. The two halves at the rear diff mounting pad are shifted so the new lower shock mount plate is not sitting square. So looks like some new Summit tubular control arms are the next project. Also installed the CPP front sway bar. Still have the drivers side rear shock to mount plus it's snowing here in Mi so haven't had chance for a test ride yet. |
