Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 01-17-2018, 11:42 PM   #1
EA274
Truck Grounding
I own a 1982 Chevy C10 pick up with a 350 in it. It cranks up without any issues, but none of the electrical systems seem to work. None of lighting (headlights, turn signals, back up lighting, stop light and everything under the dash) works. All the fuses are good and then I used a test light connected to the battery to see if there was a short. As I pulled each fuse out, the test light stayed on indicating a short somewhere, but that didn't help. Then I did a visual check of all the wiring, checked for loose connections and also to see if there were any wire grounding out somewhere all to no avail. Does anyone have any suggestions on where I can go from here?
EA274 is offline   Reply With Quote
Old 01-18-2018, 06:21 PM   #2
treveiger
treveiger's Avatar
Re: Truck Grounding
I'd check and clean all your grounds. Best way to do this is with a multi meter. There are several YouTube videos on how to do this. You basically check the resistance from your negative post on your battery to where your ground locations are. Also dielectric grease is your friend to help prevent future issues.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-18-2018, 06:54 PM   #3
fun in dirt
fun in dirt's Avatar
Re: Truck Grounding
Sounds like maybe part of the fuse block is dead. Not sure on ' 82, but know on like an '85 it has a junction block on firewall ... is there any main wires there not connected? Or wires to/from it burnt (maybe a fusible link)?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 01-18-2018, 08:28 PM   #4
davischevy
davischevy's Avatar
Re: Truck Grounding
Run a ground wire from the battery and hook it to a ground inside the truck to check the bulkhead at the firewall.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-18-2018, 09:55 PM   #5
EA274
Re: Truck Grounding
I'm not sure how to check the bulkhead, I'm still learning how to use a multimeter.
Old 01-27-2018, 06:48 PM   #6
EA274
Re: Truck Grounding
I separated the fuse block from the bulkhead wiring and found quite a bit of gunk. Attempted to spray it down with carb cleaner, but it didn't anything to dissolve it. Do you of anything that could dissolve that gunk?
Also, I think I did find a bad fusible link. Does it have a thick one inch long cylinder around the wire?[IMG][IMG]IMG_20180120_155126657[/IMG][/IMG]
I've attached a couple of images of the fuse block to show you what I was referring to. I'm not sure if you'll get them because I'm not sure if I did it right.
Thread Tools
Display Modes
