Old 02-20-2017, 01:29 AM   #1
Jcfcamaro
Jcfcamaro's Avatar
700r4 transmission
Wanting to put a 700r4 transmission in my 72 k10. What year or ? Do I look for to bolt up to my transfer case. Any help would be great. There's a couple for sale local, but I don't want to buy something that won't fit or work.
Jcfcamaro is offline   Reply With Quote
Old 02-20-2017, 04:50 AM   #2
andrewmp6
Re: 700r4 transmission
81 and newer 1/2 ton and some 3/4 tons had them,As far as your t case bolting on i kinda doubt it with out a adapter kit.What t case you have now ?
Old 02-20-2017, 08:49 AM   #3
Bigdav160
Bigdav160's Avatar
I put one in my Suburban. It's great.
Since the 700R4 is slightly longer than the TH350, I found it easiest to move the engine mounts forward ~1.5". That required lengthening the exhaust, using a shorter fan shroud and moving the shifting linkage pivot forward.
Any 700R4 from '86 to '92 ('93 car) will work fine. Some people prefer the '87-'92 due to improvements (forward accumulator added).
To mate the 700R4 to a NP205, the easiest method is this advanced adapter
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-20-2017, 01:56 PM   #4
Jcfcamaro
Jcfcamaro's Avatar
Thanks. When I bought my rolling drive train project I asked about the motor and trans. He replied it was working fine before they tore the whole truck apart. So I'm sure the turbo 350 needs rebuilt. I think I'd be better off spending a little more on a whole better transmission.
Old 02-20-2017, 10:56 PM   #5
andrewmp6
You can grab a 700r4 with the np208 in it cheap used.
Old 02-22-2017, 02:59 PM   #6
Jcfcamaro
Jcfcamaro's Avatar
What's the average cost to have a 700r4 rebuilt at a good shop. Seen monster transmission online.
Old 02-23-2017, 03:21 AM   #7
andrewmp6
If you drop it off and pick it back up at a trans shop im guess 500 to 800 bucks depending the shop really.And if you want to upgrade anything on it thats the best time to do it.Or if you want to run a non stock t case to that trans the adapter kits make you change out the output shaft so again prefect time to do that also since you almost gotta gut the trans to do it.
Old 02-23-2017, 12:03 PM   #8
LEEVON
LEEVON's Avatar
I use '87 up, there is a "vein" on the case that identifies them. I paid $100 for my last core and $750 for the build, with an S10 converter and standard upgrades. That is probably shop rate, so figure $900-1000 retail. I would just see if your rebuilder has a core, instead of looking for one yourself.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-23-2017, 07:17 PM   #9
72_K10_Vegas
72_K10_Vegas's Avatar
I installed the 700R4 in my 72 K10 as well. Very happy with it. I did move the motor for (mine ended up 1-7/8"). Off Road Design was very helpful with the adapter.
The only thing I really had to work on was making sure the front drive shaft cleared the transmission pan. I had a notch put in and re-welded the pan. The clearance went from about 3/8" to 1" +-.
I would be interested what others have done with that issue.
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 02-24-2017, 03:36 AM   #10
andrewmp6
72 k10 vegas what t case did you use ?And some adapter kits are made so you can clock the t case a little which can come in handy when needed.
Old 02-27-2017, 02:15 PM   #11
Jcfcamaro
Jcfcamaro's Avatar
Called 2 shops today about 700r rebuild. 1st shop said he didn't like them said it wouldn't hold up and only does Certified transmission installs and didn't think they would build me a trans with my supplied output shaft. 2nd shop will rebuild them but kinda said the same thing. Said the torq converter runs hot and told me I needed to run a 350 or 400 turbo. He quoted me 1200 to 1500 on the 700r and 600 to 700 for my turbo 350.
Old 02-27-2017, 10:54 PM   #12
sweetk30
sweetk30's Avatar
they don't know squat . . . .
tail shaft is a tail shaft if for the correct tranny . . .
and a correct built 700r4 with info on the end use it will get you a unit that will hold just fine.
call this guy up greg . he is over on ck5.com a lot and gives super help and info on tranny questions. he has built a few for members and shipped them . I have done parts deals with him and super stand up guy .
http://www.phoenixtrans.com/
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-28-2017, 08:05 PM   #13
Jcfcamaro
Jcfcamaro's Avatar
Thank you. My thoughts exactly. They've been using them for years. I'm thinking they don't like working on them
Old 03-26-2017, 05:16 PM   #14
Jcfcamaro
Jcfcamaro's Avatar
Would this one work. I asked the year, but they haven't got back with me yet
Old 03-26-2017, 10:24 PM   #15
sweetk30
sweetk30's Avatar
2wd drive trans and tail shaft . might have to swap the tail shaft = full tear down of both to get shaft and swap shaft.
plus a used untested by YOU 700r4 = quick waste of time and MONEY in my book .
Old 03-26-2017, 11:36 PM   #16
Jcfcamaro
Jcfcamaro's Avatar
Most shops want a core. And to bolt this up to my transfer case I'll have to buy the special tailshaft anyway. He wants 50.00
Old 03-27-2017, 11:27 AM   #17
sweetk30
sweetk30's Avatar
good core range is 50 or so bucks .
if doing a 700 to 205 build check tranny pan to transfer case front output yoke clearance . . . I cant recall 100% if its this combo or not that gets real close . as I don't play with 700r4 trannys my self.
if it is the super close one lots of guys run the 700r4 to th350 spacer between the tranny and tcase for the extra clearance . and if I recall it saves you from shaft buy for the different length .
Old 02-10-2018, 08:32 PM   #18
Harley03joe
Does Any One Know Where This Filter Goes On The Pump ? Can It Be Put In With Just Taking The Pan Off ? Or The The transmission Have To Come Out ?
Please Let Me Know With Pictures OK
Thank You
Harley03joe
1931 Ford Like New And For Sale
2004 Harley Davidson Heritage Classic
1987 Chevy R 10 Silverado
2007 Azera
2011 Cadillac CTS Premium
Harley03joe is offline   Reply With Quote
Old 02-10-2018, 10:08 PM   #19
goldenburb
goldenburb's Avatar
Got my 700r4 trans rebuilt for $800 +100 for a cable that goes to the carb.The bad thing was it was warranty for a year the day I picked it up. And it sat for 6 months so I lost that time.
I got an adapter for a np205 from Matt @ advanced adapter for $450. still doing homework on is what motor works best.with out an other adapter.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 04-15-2018, 02:00 PM   #20
Gearzandgunz
Hey Joe might have already found this out but the pump has to come out to install that filter it sits at about the 1 o'clock position hope this helps
Gearzandgunz is offline   Reply With Quote
