Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 09-17-2017, 11:57 AM   #1
mike16
Krylon over EDP coating, ready to paint?
I bought a left and right rear view mirror from classic parts. Very nice but it has , I'm guessing some sort of EDP coating on them. elsewhere in thier catolog its claimed that the EDP coating is ready to paint.
I painted right over the edp coating without any prep and the paint, Krylon white, chips off with almost no effort.
what am I doing wrong?
mike16 is offline   Reply With Quote
Old 09-17-2017, 12:20 PM   #2
Dayton601
Junior Member
Dayton601's Avatar
Re: Krylon over EDP coating, ready to paint?
should have at least hit it with scotch brite , also krylon is not very durable anyways, but its the easiest, sand it off, or use thinner, then next time just lightly mist the paint on, then finishing it up with a couple of coats, not to heavy each time till its covered, but the best paint would be a two part paint like epoxy something that has hardener added to it, something with hardener withstands the bugs better,
that's my 2 cents worth,
Dayton601 is online now   Reply With Quote
Old 09-17-2017, 01:28 PM   #3
Foot Stomper
Foot Stomper's Avatar
Worth more than 2 cents for sure!
I'd add that Krylon is nothing more than enamel fast dry.
If you apply as described by Dayton, it should hold on better. If you didn't scuff it, that's your biggest mistake.
An epoxy will stand up to abrasions and chipping but will chalk in time as all epoxies are not UV resistant. 100% of them with no exceptions.
A 2 part urethane is ideal but would require spray equipment.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-19-2017, 07:09 PM   #4
mike16
thanks. I did the misting of layers of paint but not the scuffing or wipe down with solvent
this paint stuff "mistify's " me. Ha Ha just had to say that. sorry... shutting up.
Old 09-23-2017, 06:16 PM   #5
mike16
when I went to remove the bad paint, the edp coating started comming off randomly in certain places. So I striped it all off and started with bare metal. Alls good
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
