Old 10-02-2017, 12:53 PM   #1
72ironmike
72ironmike's Avatar
Paint codes & dash colors
My Blazer shows a spid paint code of 11522-AA (Bronze). The dash beneath the windshield is a different color. How do I find a paint code for this part of the dash ? Thanks for all help/support.
72ironmike is offline   Reply With Quote
Old 10-02-2017, 02:19 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Paint codes & dash colors
If the bronze is the factory color..the dash has been repainted at some point in time.....the inside and outside were never coded to be two different colors on these K/5s
Edit:...misread the post.....I thought the OP was referring to the actual dash area where the gauges..glove box, etc.... are.....not sure about the upper part
have heard the were painted flat black...?
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-02-2017, 02:39 PM   #3
hemi43
hemi43's Avatar
I thought all the dashes were painted with a satin black to prevent glare ?
The one that dies with the most tools, wins !
hemi43 is offline   Reply With Quote
Old 10-02-2017, 05:19 PM   #4
raggedjim
raggedjim's Avatar
Not all, some colors used a darker flat paint, such as a 503 truck would have the top of the dash painted a dark flat green. Usually they tried to match the dash pad with a flat paint in the same color.
Rg
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 10-02-2017, 05:53 PM   #5
72ironmike
72ironmike's Avatar
This dash topside has never been painted except from the factory and it is a light tan color ?
Old 10-02-2017, 05:55 PM   #6
72ironmike
72ironmike's Avatar
Rg
Well I have the dash pad out so I guess I can take it in to color match.
Old 10-02-2017, 10:56 PM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Mike what color was your dash pad? Interior color/code? If parchment interior it probably has a light saddle dash pad w color coordinated to the pad. Would be flat as mentioned with defrost vents painted to match (if good color on the vents these could be used to match the paint).
Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, AASmedic, SoCoC10, Lumaestas, carbuff382
Old 10-03-2017, 09:21 AM   #8
raggedjim
raggedjim's Avatar
Is this the right bronze? If you use the tan dash pad it should be flat tan, if it has a black pad, then you go with flat black.
Rg
Roger
'70 GMC Jimmy 2wd
Old 10-03-2017, 10:19 AM   #9
72ironmike
72ironmike's Avatar
Why do small projects always end up being more ?
Was just changing the windshield out and replacing carpet.
Then, we should make sure the frame is cleaned/painted. Frame is excellent !
Then, now's the time to change out the dash pad.
Then, we should paint the dash top.
Then, since we took the dash cluster out to get to the dash pad we need to replace it with a tach dash.
Then, since we dropped the column we need to put the NOS tilt in.
Then, we should go ahead and put the rear panels in.
Then if we put the rear panels in, we should replace the front metal panels with vinyl panels to match.
I'm sure this is not all. Reminds me of one of the first trucks I purchased. A 67 short step out of Alabama. Thought it was rust free. Was going to paint and drive. Went to put a sliding rear window in it and found some pinholes around the rear glass frame. That truck ended up in individual pieces on the garage floor !
And then ???????????????????????
Thanks Pete.
Old 10-03-2017, 10:20 AM   #10
72ironmike
72ironmike's Avatar
Rg
Looks like everything is the same. Body color and dash top/ pad color. Is the dash top and pad painted with the same flat color ? Thanks everybody.
Old 10-03-2017, 11:30 AM   #11
raggedjim
raggedjim's Avatar
No, the dash should have vinyl in the color you want and then you have to find a paint that is flat that matches it (I used a olive drab camouflage paint to do my upper dash, not exact but close enough for me.)
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 10-03-2017, 02:57 PM   #12
72ironmike
72ironmike's Avatar
Good luck, Rg
Thanks Roger.
Old 10-03-2017, 03:18 PM   #13
72ironmike
72ironmike's Avatar
Here are some haphazard poor pics taken in the storage shed !
Only rust around frame is where seam sealer was ? Gonna Por 15 these areas before seam sealing, primer & paint.
Old 10-03-2017, 03:20 PM   #14
72ironmike
72ironmike's Avatar
Last pics for now
Old 10-03-2017, 10:08 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
She's a beauty! That color is typical for parchment interior without black dash pad. I don't know the code. If you don't want to risk breaking a defrost vent to use to match I may have one that I can send if helpful. Pete
Old 10-04-2017, 04:54 AM   #16
72ironmike
72ironmike's Avatar
Thanks Pete. I got lucky and one came out without damage. On to the paint store !
Old 10-04-2017, 08:57 AM   #17
raggedjim
raggedjim's Avatar
Good looking blazer, I wish I had started with one that clean.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 10-04-2017, 10:12 AM   #18
rsavage
rsavage's Avatar
I believe GM cars and trucks used a 60% gloss as opposed to flat. Total flat does not look correct.
1961 C1 Corvette
70 GTO convertible numbers matching 400, 4 speed
69 Blazer 4 WD. Latest restoration project
2018 Durango 392 Hemi SRT 0-60 4.4 sec, 12.9 1/4 mile
rsavage is offline   Reply With Quote
Old 10-04-2017, 10:34 AM   #19
72ironmike
72ironmike's Avatar
Can anyone else weigh in on this ? The black color I have seen on the top dash does not look total flat ? Any help appreciated.
Old 10-04-2017, 09:20 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Mine with original paint appear flat. So much so that's the finish I went with on the blue blazer build: https://67-72chevytrucks.com/vboard/...&postcount=137
If the point is to reduce (or eliminate) glare shouldn't the finish be flat?
Old 10-04-2017, 09:36 PM   #21
72ironmike
72ironmike's Avatar
That is what the paint guys told me today.
Old 10-05-2017, 06:05 AM   #22
Tomo
Great topic I had no idea. What would be the correct top of dash color for a medium olive 70 with black interior?
Tomo is offline   Reply With Quote
Old 10-05-2017, 09:25 AM   #23
raggedjim
raggedjim's Avatar
If the dash pad is black the dash top will be flat black.
Roger
'70 GMC Jimmy 2wd
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
