10-13-2007, 10:10 PM | #176 |
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
well, its been awhile since I posted.... due to the fact that its been awhile since I have touched the truck. I did pick up a nice black steering wheel off Ebay for $30, it has a few small cracks but it's a better start than my original... Decided to finally swap out those crappy motor mounts for a slightly less crappy set (both from India!). Atleast the 7/16" center bolt fits in this set.... Also cleaned up my power steering brackets since I noticed that they go with the motor mounts. Finally installed the "spin-on" fliter too! Hoping to get the carb and HEI back on this week and fire it up again....
It's always motivation to hear them run ya know....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-14-2007, 04:46 PM | #177 |
I love how you grafted the snow blower on the side of the frame!
10-14-2007, 08:59 PM | #178 | |
I picked that up for my 316 a few months ago but can't mount it till the mower deck is off... So there it sits
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-14-2007 at 08:59 PM. |
10-14-2007, 09:25 PM | #179 | |
FarmBoy.
ahh..i love the look of fresh orange small blocks.
it's a beautiful thing. looking goooood. -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
10-21-2007, 08:42 AM | #180 |
Decided to work on the ramhorns... Broke out the wire wheel on the grinder to prep for Hot Jet coating.... I'm having trouble with the AIR holes that are plugged in both sides. I'm trying to replace them with alan head plugs but 40 years of heat and rust are working against me....
I also seem to have some kind of alignment problems with the front pulleys.... What did I forget? I measured the old pump with the new and it's only 1/8" difference so it must be something with the crank pully.... any thoughts? Carb is on, HEI is back in.... once the ramhorns are coated then its time for plugs, wires and hopefully starting it again... Oh yeah, my spin-on filter adapter is leaking badly just while priming the engine... Anyone used on of them with success or should I just go back with the canister?
10-22-2007, 08:52 AM | #181 |
Any chance you could upload a photo of the carb and throttle cable, kick down cable. I am reinstalling this now and want to make sure it looks good and works right.
10-22-2007, 06:39 PM | #182 |
mine has a manual tranny so no kickdown cable... and it has a throttle bar not cable since it's a 68. I also swapped the Q-jet for a Holley so it might look different anyway..... sorry
10-22-2007, 09:38 PM | #183 |
Noobie McNoobster
I went the easy route...I bought a set of good used mid-60's corvette rams horns for about $100 delivered. I used both 3747038 RH manifolds since I am using late model alternator brackets...
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
10-22-2007, 09:52 PM | #184 |
I was going to buy a 2.5" set that one of the vendors was selling but wanted to stick with my alternator...
10-25-2007, 04:47 PM | #185 |
Is the balancer seated all the way in? It could cause the pulley to be too far out. Is that gun a sand blaster? I am looking for the blaster that hooks to the pressure washers? Looking good!!
10-25-2007, 06:15 PM | #186 |
I never removed the balancer... I think that it's the aftermarket el'cheapo water pump from Advanced auto parts. It works for now but I might try to return it later. The little sandblaster does OK but you still eat half the media (reminds me why I hate sandblasting) when it bounces back into your face.
Thanks...
10-25-2007, 06:54 PM | #187 | |
I have a radical idea!
I hate to be the buzz kill for you, but rust-free sheet metal is almost non-existent here. It's probably a lot better than what ya'll have, but when they are parked, the humidity does take it's toll.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-25-2007 at 11:11 PM. |
10-25-2007, 09:11 PM | #188 |
YIKES!
guess I need a bigger stick then.... The sheetmetal can't be nearly as bad as mine or others in our boneyards.... I'm heading down to Ft. Rucker on Saturday to spend the next 6 months away from home.... gotta do something ya know..
10-25-2007, 11:11 PM | #189 |
Oh, there's definitely plenty of salvageable parts, its just that a lot of people north of here assume everything is perfect. What we consider badly rusted is usually better than average up there. I noticed on another you were talking about going to Moultrie. I highly recommend. There's always lots of good stuff there. Ft Rucker is only about 2 1/2 hours from here, and there are several good yards here locally that have plenty of 67-72's. When you get down and settled, shoot me a PM and I can show you around if you need some stuff.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
10-26-2007, 08:04 AM | #190 |
cool thanks for the assistance. I'll be sure to look up all the Alabama members in the next few weeks.
11-13-2007, 12:18 AM | #191 |
there is a place 45 min north of you called the truck farm its 10 min nne of troy al. need to look in to it 10ac of nothing but trucks
bogey5 |
11-13-2007, 03:48 AM | #192 |
cool, thanks for the tip...i'll look it up
11-13-2007, 04:58 AM | #193 |
looking good Mike!! good luck on your trip.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
11-13-2007, 05:18 AM | #194 |
KEEP ON TRUCKIN'
It's coming along Mike, looking good.
67_C-30, I'm not usually afraid of snakes but I will admit that I did jump a bit when I scrolled down and saw that thing.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
11-13-2007, 07:50 AM | #195 |
Not many trucks like yours with the clearance lights.Lucky find!!!!
11-13-2007, 07:32 PM | #196 |
Noobie McNoobster
Anyone know where the clearnce lights can be obtained, I just noticed my truck had them originally, and I am thinking about putting them back.
11-13-2007, 07:41 PM | #197 |
The only one's that are identical to mine are in the LMC catalog. Only $37 for a complete set so let me know how they look. Mine are shot so I will be replacing them with the LMC set.
I did get the truck running before I left for school in Alabama. Realized my radiator is shot though... boy, once that pressure started building it was springing leaks like old faithful! I only ran it for about 5 minutes or so... thanks for the words and good luck to everyone over the winter. I just heard that another classmate from flightschool died in the blackhawk crash in Italy. That's two out of 40 in 6 years. sad day...
04-13-2008, 08:32 PM | #198 |
Well, I am back from my Lower Alabama trip now, what a way to spend the winter!
Just picked up a new toy that I got on Ebay. Ready to start working on that cab now! Here's how the truck sat all winter That spin-on oil filter kit leaked like crazy so I went back to the canister type. I would like to get the cab blasted but not sure if the budget will allow that.... More to follow...
04-13-2008, 09:21 PM | #199 |
Nice welder Mike, is it a 140 or a 180?
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 |
04-13-2008, 09:23 PM | #200 |
Can't wait to retire!!
Glad to see you're back...looking forward to more progress.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
