Old 02-26-2010, 08:22 PM   #1
Justin36
Justin36's Avatar
700r4 Passing gear cable ????
I have a 83 Chevy, it had a inline 6 with 700r4, i just put brand new 700r4 with a brand new zz4 350, what kind of bracket or throttle linkage do i need to use to hook the passing gear cable back up?? thats almost all i like, i would appreciate any help lolol thanks Justin
Justin36 is offline   Reply With Quote
Old 02-26-2010, 09:01 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: 700r4 Passing gear cable ????
It depends on what type of intake manifold you are running you could spend 40 bux and get one like in this pic from summit or go to the U-PICK-IT junk yard for probably 5 bux and just remove one from just about any chevy truck that uses a 700R4 and adapt it to fit.
Personally id go to the junk yard for it.
Also it's known as a TV CABLE.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-26-2010, 09:47 PM   #3
78-5.3
78-5.3's Avatar
yeah there known as a tv cable on the 700r4 not a kickdown as on a 400 0r 350 trans
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-27-2010, 10:20 AM   #4
James McClure
One shot, one kill.
Justin, like 78 said, BUT add this, it's important or that brand new 700 will be junk real quick. The detent cable MUST be adjusted properly for the trans to work properly and live a long productive life. If you don't know how to adjust it find someone who does. If you can't find anyone try to adjust it yourself. There is a tab on the cable end you have to push in towards the cable casing. Push tab in and draw back on cable until it stops. Now get into the vehicle and slowly push the throttle as far as it will go (eng not running) and you will hear it clicking (normal) when you can't push any farther its adjusted. It can be "tailored" a bit to move shift points up or down but I don't recomend doing that yourself if your not familiar with the adjustment process and trans function the adjustment affects. Hope I didn't scare ya. BTW, 400's don't have a down shift cable, it's electric. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-27-2010, 10:41 AM   #5
Justin36
Justin36's Avatar
thanks guys
Old 02-27-2010, 11:08 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
You also need an additional carburetor linkage bracket to make the TV cable work properly. It is a geometry corrector kit. The TV cable needs just the right travel distance with throttle opening to work right and this bracket makes standard T-350 style kick down linkage on carburetors work with a 700-R4 / 4L60. You can get them for Edelbrock carbs and for Holley carbs.
http://www.summitracing.com/search/P...e&autoview=SKU
Easy to install but critical to make the trans work properly.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-27-2010, 01:47 PM   #7
Justin36
Justin36's Avatar
Went to auto zone just to check and see, and they had the carb linkage with tha dentent bracket!! thanks for the help guys
Old 02-27-2010, 05:47 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I used the edlebrock bracket.
Proper way to adjust the TV cable: http://www.73-87.com/7387garage/drivetrain/tvcable.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
