05-16-2011, 11:04 PM | #1 |
Grandpa in the rustmobile...
Emergency Flasher button
My emergency flasher button is broken off clean @ the column. All the reproduction ones ive seen are different (black, and the design is different).
I can get one out of a junkyard, but the hastle of pulling the steering wheel running from wasps etc is a pain, and it'll probably be brittle (40 years old). Does anyone reproduce the red style emergency flasher button? I have a pic but cant find my card reader right now. Its the button on the right of the column in front of the shifiter lever. Thanks
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-16-2011, 11:17 PM | #2 | |
Re: Emergency Flasher button
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-17-2011, 12:44 AM | #3 |
I've got the same problem. Please let me know what you find and I'll do the same.
05-17-2011, 04:40 AM | #4 |
I posted the same question a couple of months ago b/c I have the same problem with my '68 FLASHER switch. Unfortunately no one reproduces these for our trucks. Hopefully someone will eventually b/c I would definitely buy one.
05-17-2011, 06:17 AM | #5 |
This one from Manes Truck Parts looks to have the correct red Knob... but you have to buy the whole turn signal switch to get it...
http://www.manestruckparts.com/store...&Category_ID=8
1969 CST/10 "GreenAndWhite" 1974 Nova (SOLD... End of an Era) 2000 Impala (RIP) 2008 Malibu Brand Loyal... I've never owned a Vehicle not made by Chevrolet. |
05-17-2011, 09:41 AM | #6 |
I had the same thing happen. I super glued it back together, now it looks and works like new.
1971 C20 Longhorn Custom Camper |
05-17-2011, 10:51 AM | #7 |
I dont have all the pieces lol.
Will the later style button thing work (black)?
05-17-2011, 11:56 AM | #8 |
I installed a new type one in my 68 with no problems. the plug for the wires is diffrent but it has a adapter in the kit that will plug into the stock plug. I spliced mine off the old switch and then got to looking at it and I could have just pushed the pins out and swaped out the ends.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
05-17-2011, 12:01 PM | #9 |
GMC PAUL also has the complete switch that comes with the correct knob I believe.
05-17-2011, 04:05 PM | #10 |
Mine's broken off too. I'm probably just going to buy the whole turn signal switch with the red hazard light switch from Rock Auto.
05-17-2011, 08:17 PM | #11 |
Can you just get the red thing from rock auto
05-17-2011, 10:48 PM | #12 |
Nope. It's part of the turn signal switch.
05-18-2011, 03:06 AM | #13 | |
EDIT: Just found one on eBay that is an NOS switch. Seller wants $60. Too steep for a switch to me though even if it is NOS. http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories Last edited by Chevyman680063; 05-18-2011 at 03:22 AM. |
05-18-2011, 10:52 AM | #14 |
I guess I'll make a WTB add?..
05-18-2011, 02:05 PM | #15 | |
It was broke and I was switching everything over to "Billet". I had everything switched over to Billet,EXCEPT the Broken 4 Way Flasher Button. Had to have my Mechanic change out the Cam Gear/Switch in the Column, (the turn levers were shot too). Once it was changed, it actually had the fitting in the Switch for the "Screw-In", type of button, (which the one I happened to have was Billet). Worked out great in the end.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 05-18-2011 at 02:07 PM. |
05-18-2011, 02:43 PM | #16 |
Is this what you're looking for? $5 to cover shipping and the hassle of going back to the PO and it's yours! I actually used to change these out to the screw in kind back when I was rebuilding tilts all the time, don't know how many I threw away.
05-18-2011, 03:31 PM | #17 |
Yeah, that looks like it!
I'll get to ya this evening when im back home. Thanks man!
05-18-2011, 04:23 PM | #18 |
I'll take it if its not brittle/about to fall apart lol. Sending PM
05-18-2011, 05:32 PM | #19 |
ls1nova71, if you find another one I'll buy it from you for $5 too.
05-18-2011, 08:54 PM | #20 | ||
Also, I just want to let you guys know what you're getting yourselves into. This is NOT designed to be a serviceable part. That doesn't mean it cannot be done, but it isn't going to be a simple bolt on deal. You'll most likley need to remove the turnsignal switch from the column, so you can work on it. Once out, you'll need to remove the two spring steel pieces on the right side, and then pull the top plastic piece of the switch off (the part that moves to make the switch work) There's 2 plastic tabs that hold it on. Then remove the little spring that spring loads the hazzard knob, it's on the bottom, you'l see it. Once that's out of the way, you'll need to get a small screwdriver and pry the OUTER metal tangs (that hold the hazzard knob on) (there are 2 inner tabs, but they are hard to remove and usually break, so don't mess with them) away from the switch. then remove the broken part. Reinstall the new one and reverse the procedure. It's not as hard as it sounds, but I did just want to make you guys aware. |
05-19-2011, 12:00 PM | #21 |
I don't work for these guys or sell stuff for them, I'm just passing on info from one of my catalogs. I found the complete switch ( w/red hazard knob- pn-67-066052) in my Truck Shop catalog for $34.00. pg.48. I have ordered from these guys before and was very impressed with the quality. I'll be ordering the new switch by the end of the week, I'll let everyone know how it comes out.
www.TruckandCarShop.com 1-800-243-8947 They are out of Orange Cal. They sent me a free catalog. |
12-13-2016, 09:53 PM | #22 |
i know this is an old topic but, i had this same thing happen to me. Does anybody have one that they would be willing to sell?
06-15-2018, 04:39 PM | #23 |
Bumping, now its 6/15/18.
My '69 is one of those where the previous owner jerry-rigged everything. There is a screw through what's left of the red button. I tried it out for the first time today, it would not turn off, had to unplug the flasher thing off the fuse block. I looked at the LMC online catalog, is the turn signal unit part of this, or what's the latest?
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
06-15-2018, 05:16 PM | #24 |
Who Changed This?
The flasher is part of the turn signal switch. If it were mine to do, I'd just buy the whole switch. All the other parts are old too, right?
06-15-2018, 05:18 PM | #25 |
Classic Industries:
Tilt: https://www.classicindustries.com/pr...s/1997961.html Without Tilt: https://www.classicindustries.com/pr...s/1997965.html |
