Old 06-18-2020, 01:44 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tow Hooks: Post your foundry casting marks
I'd like to see detailed examples of the foundry casting marks present on tow hooks for 67-72 trucks. Curious what's out there. These marks can serve as supportive evidence of an OEM part in the absence of part numbers, such as the case with some (most?) 72-only tow hooks. Perhaps for this style one foundry included part numbers but another did not.
Here's a borrowed example that shows what I'm after adjacent to the part number but it lacks detail enough to really identify the mark.
Old 06-18-2020, 02:30 PM   #2
MJN
MJN's Avatar
Re: Tow Hooks: Post your foundry casting marks
Those marks are present on my hooks, not the best lighting with glossy paint but hopefully you can make them out. One hook is more pitted than the other but you can still make out the faint outline of the mark by the part number. Got these out of the junkyard- off an early 50's GMC COE grain truck, the yard owner just looked at me funny and said if you can get them off go for it.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-18-2020, 02:49 PM   #3
Graham57a
Graham57a's Avatar
Here’s the best pic I could get of mine. Almost looks like a U with a hexagon around it
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 06-18-2020, 04:44 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
First is an extreme without a part number, second is a 69-71, third and fourth is a 67-68, and last is a pre 67.
Some extremes have part numbers, some don't. Certain extremes seem to have fine thread bolts also if I recall correctly.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-18-2020, 06:35 PM   #5
Bones72Super
Bones72Super's Avatar
Great thread Pete, however these hooks are forgings not castings. I could be wrong but I would think in a shock load scenario GM would use a forged unit over a cast unit.. Castings have incredible compression strength but don't do well under tension/bending/leverage. Just thought I would point that out, not trying to nit pick or bash
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 06-18-2020, 08:52 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great point. I’m sure you are correct. I’d like to learn more about the manufacturing process. Am envisioning some molten steel poured into a mold.
Here’s a set of 72-only I have on the shelf. Look like a circle (or a worn hexagon) with a “U” and no part numbers.
Thanks for posting. Let’s see some more.
Edit: quick video here reviews basic differences between forging vs cast techniques. I have a lot more appreciation for these forged pieces: https://www.youtube.com/watch?v=H9qTcAyMuPU
Old 06-18-2020, 11:05 PM   #7
Chevyland
Chevyland's Avatar
72 extreme bends
With
Foundry
And
Part #
Chevyland is offline   Reply With Quote
Old 06-18-2020, 11:10 PM   #8
Chevyland
Chevyland's Avatar
Another set of extreme’s
With foundry markings
But
No part number
Old 06-19-2020, 07:27 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Interesting that so far these all have a “U” logo/mark. That denotes a particular foundry - I wonder which?
Also, it seems as though the non-part numbered 72s have a mark featuring more of a circle rather than a hexagon.
Old 06-19-2020, 08:49 AM   #10
dennislbrooks
dennislbrooks's Avatar
Same casting mark as Deadhead and others.
p/n 3663349-50
http://67-72chevytrucks.com/vboard/s...d.php?t=708395
Frontwards , backwards, right, wrong -- supposedly these correct 60-68 tow hooks in my opinion are overkill for a 1/2 ton or 3/4. I bought the pair and they had what I think are the original 5/8" grade 8 fine thread bolts and I mounted them with 4 new grade 8 coarse threads with the thick washers and lock washers on the inside. I used 69 front leaf spring hangers --I do not know if they differ in design of a 67 K10 but there was little room for mounting them on the frame.
As I said earlier they both curl the same direction which is not noticeable but either correct or incorrect. If anyone has a pair of p/n 363349-50 that curls opposite mine I will trade you one.
There is no gm info I can find and it appears that 67-72 has more info -right or wrong- on them than anywhere on the web. My assembly book does not show them at all.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 06-19-2020, 10:18 AM   #11
tristan
Extremes. Both curved in the same direction so same part #.
tristan is offline   Reply With Quote
Old 06-19-2020, 10:21 AM   #12
tristan
1969-72 non-extremes. Not curved in same direction so different part # on each.
Old 06-19-2020, 11:03 AM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Cool thread Pete... I need to round a set up for my truck.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 06-19-2020, 11:27 AM   #14
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Here's mine, no part #'s on these extremes. Great thread Pete. Cool video too. I never thought I would learn something from a golf video....lol
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-19-2020, 06:09 PM   #15
Bones72Super
[QUOTE=DeadheadNM;8759996]Great point. I’m sure you are correct. I’d like to learn more about the manufacturing process. Am envisioning some molten steel poured into a mold.
Pete, have a gander at this wonderful video from the 50's. You will have a good understanding of the process and benefits of forged products. Plus there is some amazing equipment and machinery that is just plain awesome
https://m.youtube.com/watch?feature=...&v=v2_0V58ocq4
I fixed the link, it should work now
Old 06-19-2020, 06:58 PM   #16
Killer Bee
Killer Bee's Avatar
last time this came up, I searched thoroughly but could not find Hex U listed but several others here with logo pictures of this type of marking..
Alloy Artifacts - Trademarks and Logos
from browsing that site, they don't seem much interested in taking on our query but maybe a smooth talking rep could get one their researchers on the case..
had these pictures handy of a couple pair of regulars..
I'll try to get better pictures of these and the extremes I have..
Old 06-19-2020, 07:27 PM   #17
Killer Bee
Killer Bee's Avatar
Pete, have a gander at this wonderful video from the 50's. You will have a good understanding of the process and benefits of forged products. Plus there is some amazing equipment and machinery that is just plain awesome ��
http://Watch "FORGING HISTORY VIDEOS...be/v2_0V58ocq4
I did some work in Shultz Steel some years ago.. they asked us to speed up the machines that moved steel from the furnaces to the presses.. scale size of this place is nothing short of amazing! the parking lot would shake when the big presses were running.. had a great time working in there several days.. cranked up the hydrostats on their specialized handlers.. they were hauling azz in there with giant chunks of steel glowing almost white and bright as the sun!
http://www.shultzsteel.com
some pictures here http://testshultzsteel.com/Equipment/Capabilities.aspx
check out what they have now
Huge hydraulic press goes to work in California
Old 06-20-2020, 11:00 AM   #18
IronCanine
I'm trying....
IronCanine's Avatar
'71 Flint Blazer. Not great pics, tried to sharpen them a bit.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 06-20-2020, 05:52 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Bones - I’m awestruck at the content in those films. Thanks for posting. Amazing. I’ve got a lot of admiration for those steel workers and grateful to have real forged examples.
Here’s a rear tow hook shot from the first film.
Thanks for posting guys.
Killer I’ll check that out here shortly. Too cool. BTW the US Patent office likely has this forge mark/logo in their searchable data base. Looks like the searches are somewhat convoluted but I’ll give it a go when possible.
Old 06-21-2020, 12:08 AM   #20
davischevy
davischevy's Avatar
These have the marking, but no part number. Notice the white paint.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-21-2020, 05:56 AM   #21
farmall
farmall's Avatar
The octagon with the letter inside was American Steel Foundries with the letter being the location of the city or branch.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 06-21-2020, 07:27 AM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I noticed that when I stumbled upon a list of WWII era foundry marks but those here are hexagons so not certain it’s the same company. Example list here: http://web.inter.nl.net/users/spoels...04/foundry.htm
Old 06-21-2020, 01:45 PM   #23
davischevy
davischevy's Avatar
Did American Foundries have a location the started with a "U"?
The Hex symbol sure points to them, but that Registry doesn't show a "U" location.
other Larry
Old 06-24-2020, 05:26 AM   #24
dennislbrooks
73-80 tow hook casting -- Same U
328072
Old 06-24-2020, 06:04 AM   #25
Killer Bee
Killer Bee's Avatar
borrowing pictures of these I just bought from Ironhorse, hope he doesn't mind
they match the profiles of the fronts perfectly so maybe some genetic relationship although they have different forge marks..
took these close up pictures of part numbers and logo but C or Horseshoe X doesn't seem to match the marks we've discovered so far..
maybe Keith knows someone from the plant who would have some leads?
right
left
