Old 03-14-2012, 09:39 AM   #1
Indian113
Indian113's Avatar
Changing Throttle Body's
I bought a 2004 5.3 with a DBW throttle body, can I change out the throttle body to a cable throttle body or do I need a new intake too?
Indian113 is offline   Reply With Quote
Old 03-14-2012, 10:23 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Changing Throttle Body's
Should be a direct swap onto your intake. Minor re-wire and PCM programming will be required as well...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-14-2012, 10:42 AM   #3
terrylgreenjr
I had a cable intake and a drive by wire intake and the vacuum line that was behind the throttle body was different. I am unsure of the year model on the intakes I have though
terrylgreenjr is offline   Reply With Quote
Old 03-14-2012, 01:36 PM   #4
ls1nova71
ls1nova71's Avatar
Besides the rewiring and PCM tune changes already mentioned, you will probably find the threaded inserts where the throttle cable bracket bolts on, wont be there, just empty places where the inserts go.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-14-2012, 02:49 PM   #5
Indian113
Indian113's Avatar
Thanks for the advice,this is all new worlds for me! I'm looking forward to getting this in my S10 it should be a better DD than the 327 I had in it.
Old 03-14-2012, 07:29 PM   #6
softballnrd27
Always a work in progress
softballnrd27's Avatar
I did the same thing and instead of trying to find inserts or a new intake I just epoxied some bolts(head down) in the empty holes. I had to round off the the bolt head but I kept it as a snug fit and then put some epoxy in the hole, put the bolt in the holes and then some more epoxy around it to keep it steady. It holds pretty good and the bolts are hidden by the engine cover any way.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-14-2012, 07:38 PM   #7
Indian113
Indian113's Avatar
THANKS! thats a real good idea-I'm going to use your advice
