02-07-2019, 04:21 PM | #1 | |
Re: 72 control arms vs 73
Do the older style arms need to be greased more often? Do the arms with rubber bushings provide a smoother or less jarring ride? |
02-09-2019, 01:08 PM | #2 |
As long as you’re not trying to interchange a 1 ton arm with the bolt on setup they will swap out. Lowers I believe the bolt holding the shaft onto the crossmember got larger in diameter. Uppers are a direct bolt on. As far as greasing goes it’s no different than any other metal on metal wear item. Grease items when doing usual maintence and it shouldn’t matter.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-11-2019, 11:37 AM | #3 | |
