03-21-2018, 11:52 AM | #1 |
Strongman Garage
Dana 60 Hub Removal Video
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
03-21-2018, 08:06 PM | #2 |
Re: Dana 60 Hub Removal Video
do not need to tear apart whole locking hub . 1 center snap ring off stub shaft and 1 out of the hub/rotor body . then 2 hub screws in to let you pull on them and pop out hub complete .
drive the caliper wedge the other way next time . much faster and easy to swing the hammer . the socket you didnt like is the better one in my opinion . the second one if not careful can break the little tiny pin off on the inner nut and screw you on a sat/sun when no body has that part . so watch your self . the snap ring pliers will pull the lock ring out and help install a lot better also if you have trouble getting it to move in there . and FYI: the lock ring holes are off set on the tabs location . so if off by a hair of lining up the inner pin to the washer hole flip it over . last trick - put the outer nut on a few good turns . then pull the hub/rotor down and out . the nut will catch the bearing and use it to pop the wheel seal out and not hurt the bearing . make removal super easy and you wont need a seal tool or prybar . good job on the video . these are just my few tips to help others later .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 03-21-2018 at 08:11 PM. |
03-30-2018, 05:59 PM | #3 |
Strongman Garage
Appreciate the advice for next time.
Lots of good tips
03-30-2018, 08:32 PM | #4 |
no problem . i have had prob over 1 dozen my self and worked on about as many .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
