08-02-2010, 01:41 AM | #1 |
tire pressure monitore system light
hi! im new to this part of the board and i just bought a 07 chevy and the tire pressure monitor light will not come off. the tire pressure is good 35 psi. i dont have an owners manual either so how would i get it to go off?
1965 c/10 swb 1969 c/10 lwb |
08-02-2010, 11:01 AM | #2 |
Re: tire pressure monitore system light
check your spare tire also. they have 5 sensors if the spare is low it will not go out. other then that i should reset it self once all 5 tires are the same pressure
08-02-2010, 12:09 PM | #3 |
gets board easy.......
aftermarket wheels?
08-05-2010, 09:23 AM | #4 |
no they are stock wheels but i have not thought about the spare!
08-05-2010, 09:58 PM | #5 |
I was thinking also that if the tires were rotated and a relearn wasn't done, it will also set the light off.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
08-05-2010, 10:06 PM | #6 |
no not doing the relearn wont cuase a light it will just cause you dask to read the wrong tire loaction
08-05-2010, 11:21 PM | #7 |
well its an 07.5 or what ever the first year for the new body style. its on its second set of tires and its a basic, bottom of the line truck (fleet truck). i checked the spare tire pressure and its right at 35
08-06-2010, 12:02 AM | #8 |
The better tire stores have a hand held machine that is used to reset your TPMS. The machine will also tell you if the internal battery is dead.
08-06-2010, 08:41 AM | #9 |
Old member
The spare has no senor on a GM Tahoe or any of there makes as far as I know. Take it to the dealer and let him reset the system. Takes 5 minutes. I had my 08 done yesterday as I brought it home The left back senor lit up. Didn't charge me a thing and the set all 4 of my key phomes to. I had the 2 old ones from my 07 set with the two 08 ones.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-09-2010, 08:45 PM | #10 |
lol idk if they will do it for free but they will do it!
08-19-2010, 05:31 PM | #11 |
did you just ahve tire put on when the light came on???? thinking maybe they broke a sensor when mounting the tires and yes the spare does have a sensor on some of them
08-19-2010, 10:31 PM | #12 |
Old member
truckdude239,
I've had a 07 Tahoe and now a 08 Tahoe. Neither had a spare senor on the dash. The tire may have it already in the tire but the dash only shows the 4 tires that are on the road. Mine does any way!
08-19-2010, 10:53 PM | #13 |
well its on its second set of tires and i bought it from my dads work fleet. i found out how to do the relearn and the right front wont make the horn honk but the rest do
08-30-2010, 04:41 PM | #14 | |
Old member
I was told today by the service manager at the dealer ship the spare does have the senor hooked up and it will cause the light to set if it goes bad or get's lower than 35lbs. I had to take my 08 back again today and have it relearned. They said the spare would set it off but you can't follow the manual directions for resetting it because it's not one on the dash. The low senor light will come on but the 4 position's are only for the road tires. I apolagize to you for not knowing this before. I knew the tire had the senor but didn't realize it was in the system.
11-03-2010, 01:21 PM | #15 |
72 GMC
on my 2008, this is what i had to do. set the parking break. press and hold the lock and the unlock on the fob. the DIC will display something like "relearn tire pressure". let air out of the left front tire until the lights flash or the horn toots . can't remember which. takes about eight seconds.
then do the same on the right front, right rear, and left rear in that order. after the fourth wheel, the horn toots twice. then you can fill them back up to where they are supossed to be. |
11-10-2010, 10:27 AM | #16 |
OL BLUU
I don't know if this will help you... but what I did was: turn your light switch all the way to the left and it should reset itself (did on mine anyways).
Anthony Update: I tried this again and it didn't work... must of been a conquinadence? spelling?
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 Last edited by CLASSIC87'; 12-10-2010 at 10:23 PM. |
