03-17-2018, 11:44 PM | #6451 |
Re: What did you do to your truck today? Chapter II
Teardown on my suspension. Removal of original ball joints, tie tods, and the sway bar bushings were missing. Cant get the endcaps off the upper and lower control arm rod bushings tho. Grrr.
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN 1970 Chevy Custom. Last edited by 69GMCCustom; 03-18-2018 at 09:41 AM. Reason: Picture was upside down |
03-18-2018, 12:42 PM | #6452 | |
Who Changed This?
ETA- they weren't even rusted, having spent the last 43 years in southern California. Good luck!
03-18-2018, 02:21 PM | #6453 | |
I'll try a longer breaker bar, if that doesn't work I may have to run the down to an auto shop for a more powerful impact wrench. Thanks!
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN 1970 Chevy Custom. |
03-18-2018, 02:42 PM | #6454 |
I had the same problem last year when I did mine. A little heat from the Victor persuader and they came right off. I had to use the torch to heat up many parts for the tear down.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 03-18-2018 at 02:52 PM. |
03-18-2018, 04:01 PM | #6455 |
All I did was move it out of the garage while I moved some wheels in. Sadly, they aren't wheels for the '69. They're just taking up space.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
03-18-2018, 04:02 PM | #6456 |
Double post. We need a "delete post" button around here.
03-18-2018, 04:24 PM | #6457 |
I went to install my new Holley valve covers and found they won't fit. They're too narrow to clear the casting lug on the corner of the head. The aluminum covers are 1/4" narrower inside than the factory sheet metal ones. I'll be contacting Summit Mon. and sending them back. I'm not wanting to grind down that lug and take a chance of getting shavings in my new engine.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-18-2018, 04:35 PM | #6458 |
picked up a donor D60 4:10 LS FF GM 8 lug last weekend for the '71 K20 Sub and left it in the truck for the week..
craned it out at work Friday after shift to roll it into the wash bay for a good bath.. cleaned up real nice, no road scars, dents, or gouges and all the machined surfaces are smooth to the edges crappy weather yesterday but nice out today so I lifted it out of the truck with my cherry picker.. now for perch and shock mount research and prep for install.. for reference, going under the white one parked in the street in the background, not the blue one in the driveway..
I started out with nothing - and I still have most of it |
03-18-2018, 05:18 PM | #6459 |
P/s brackets done.
03-18-2018, 06:55 PM | #6460 |
Re-gapped that last, elusive, hide-behind-the-headers, spark plug to say the tune-up we did is complete...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-18-2018, 08:40 PM | #6461 |
Replaced gear indicator and dome light and lens from LMC
03-18-2018, 10:14 PM | #6462 |
Got the front clip removed, then drilled out the spot welds and removed both rockers. That was it, because both front and rear cab mounts are toast, along with both floor pans and cab corners. Someone had put slip on rockers on and homemade cab corner caps. Now the real fun begins.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
03-18-2018, 11:19 PM | #6463 | |
Who Changed This?
03-19-2018, 10:43 AM | #6464 |
Finally put the top coat on my frame and broken down parts to convert from leafs to coils. I'm hoping progress picks up now!
Also, updated my YouTube build series: https://youtu.be/fUetpeVKbpk |
03-19-2018, 09:25 PM | #6465 |
took apart passenger side vent window. sanded and painted. waiting on backorder rubber to rebuild
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
03-19-2018, 11:20 PM | #6466 | |
With the nice work you have done on that engine, I would be hunting for a set of vintage finners. |
03-19-2018, 11:40 PM | #6467 |
Finally got it in for last time...getting close...
03-20-2018, 12:20 AM | #6468 |
Motor/trans pulled, as well was bed.
03-20-2018, 07:53 AM | #6469 |
Old member
Got the passenger side exhaust manifold off to fix and installed the rear S/S simulators on the ramp truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-20-2018, 06:53 PM | #6470 |
I seat the motor in
03-20-2018, 07:22 PM | #6471 |
I sent the Holley valve covers that wouldn't fit my heads back to Summit and these came on UPS truck this afternoon. Ran out to the garage and threw one on and the fit is perfect. They're Billet Specialties by the way, nice stuff.
03-20-2018, 08:48 PM | #6472 |
those are very nice covers!
03-20-2018, 09:17 PM | #6473 |
Received my Classic Heartbeat rubber stuff.....weather strip, window (front and back) rubber and some door and hood bumpers...yeeeyaaaa
the thought of calling in tomorrow to "play truck" crossed my mind guess I'll go to work....just got a text that that my GMPaul stuff will be here when I get home Thursday morning.....another
03-20-2018, 10:05 PM | #6474 |
I bought my truck a set of hubcaps.
03-22-2018, 10:16 AM | #6475 |
I bent up a new fuel line to better clear my new valve covers.
