02-06-2010, 02:00 PM | #1 |
Wire Connections
I have a 72 C10 that has 90% of the wiring removed since it was a parts truck. Using the wiring diagram I saw, I was able to purchase most of the wiring new. My question is there are 3 wires coming out from the junction block. Does any one know about the black wire that runs on the back side to the same connection as the red one that runs in the front by radiator? I am having trouble locating it and could use the help. Thank you all.
Lewis Last edited by cobra1966; 02-06-2010 at 02:03 PM. Reason: grammar |
02-06-2010, 02:25 PM | #2 | |
Re: Wire Connections
are you refering to the black and black/white wires? If so they are for the ammeter they should have 2 little footbal shaped fuse holders with 3 or 4 amp fuses (circled in diagram).
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
02-06-2010, 02:35 PM | #3 |
Thank for the help out. I do see the circled fuses. Question is where do I get this connection? Will it come with any harness I purchased or need to find it off a junked truck? I prefer to buy it new if all possible
Thanks again Lewis |
02-06-2010, 02:42 PM | #4 |
How about making it?
02-06-2010, 02:44 PM | #5 |
I was hoping I could find it new somewhere. Maybe they dont. I do not like the idea of doing that unless it does not exist in the world anymore
Lewis |
02-06-2010, 03:12 PM | #6 |
http://www.newark.com/
If you decide to make it, try these folks for the terminals. Of course you can always go with the newer GM style of weather proof connectors. http://www.weatherpack.com/ Thanks for your service. |
02-06-2010, 03:26 PM | #7 |
Thank you for your help as well. Retirement is 4 away. I will go to the sites and make my connections accordingly.
Lewis |
