02-14-2020, 07:29 PM | #1 |
Master Cyl Upgrade
I am going to upgrade the master cyl on my 1997 Z71, done went through everything else on the brakes. I checked out the thread on here where you can go to a 2002 Tahoe type master, checking the pt numbers he provided I couldn't get the Duralast to come up. Done a search on Autozones site and came up with two, one for a JC5, or the other for a JH5, JH6, or JH7. Which one are you all using? I've found the adapter fitting you need.
02-14-2020, 10:53 PM | #2 |
Re: Master Cyl Upgrade
Don't know if this is the thread you looked at or another, but this thread lists several models.
https://67-72chevytrucks.com/vboard/...d.php?t=586972 Brake codes are JC2 11765 P BRK M BRAKE VAC POWER, 17" DISC/DISC, W/RWAL, 6,800 LBS 20205 E T E A JC5 11768 P BRK M BRAKE VAC POWER, 4 WHL DISC, 7,200 LBS 940211 E T E A JH5 11948 P BRK M BRAKE HYD POWER, 4 WHL DISC, 7,300 LBS 10921 E 4 E A JH6 11949 P BRK M BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS 940211 E T E A I would say by the numbers in the above thread they are using for the JC2/JC5 variation NM8089, which I believe are for vacuum assist brakes, verses the JH5/6 for Hydoboost brakes
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-14-2020 at 11:15 PM. |
02-15-2020, 11:07 AM | #3 |
One last thing you should do first
Have you ever done or had done, the "automatic bleed" process?
02-15-2020, 06:58 PM | #4 |
Was going to but my Solus doesn't have that option for the earlier trucks. Done several 99 and up with it.
02-16-2020, 08:59 AM | #5 |
Might want to try before you go to that trouble
I did the MC change. I also did a 2 piston caliper change with slotted rotors. I also made the MC push rod 1/4 longer with a spacer.
Nothing I did compared to a "proper" auto bleed. That is where the complete system is bled manually, then the auto bleed is done and then a manual bleed is done last. This one auto bleed made a world of difference. Was it as good as other vehicles brake system? NO Was it significantly better? YES I have a Solus Pro so I'm not familiar with a standard Solus and my pro will do the bleed process but I will say this, the program to do the auto bleed is not where you think it should be. If you're not sure look around. I am going to some day prove the entire problem with the GMT400's is a restriction on the brake system from the ABS. The way I plan to do so is make a patch brake line to take the MC around the ABS and go straight to the brake lines. One thing you might also want to do is try using the E-brake to stop with instead of the brake pedal. Obviously you have to hold the release handle up so the pedal doesn't lock. Try it when you are alone on a street that is not fast and try coming to a stop using just that. This can give you an indication of how well your back brakes are doing without having the fronts influence the feeling. In the mean time, I suggest you try the auto bleed first before you go the way of the MC change. I'm betting you will be surprised. |
02-18-2020, 07:22 PM | #6 |
driving is in my blood
You want the lower numbers that go with vaccum brakes.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Thread Tools | |
Display Modes | |
