Old 03-19-2003, 01:57 AM   #1
71Custom10
71Custom10's Avatar
blinker in dash stays on
Whenever I turn my lights on the left blinker indicator in the dash comes on but it shines real dim. When you turn the blinker on it goes out and the blinker functions normally. Turn it off and the light is on again. Where do I start?
Andrew
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
Old 03-19-2003, 02:03 AM   #2
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Same thing is happening to me except with my right blinker. I think it might have something to do with a bad ground but i dont know cus I havnt had time to look at it. Let me knoe if you find anything out please.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 03-19-2003, 02:52 AM   #3
mtdave2
newly minted old timer
mtdave2's Avatar
yep somehthing is grounding.. prob in the buld connector.. take the bulb out and look at it..lol
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 03-19-2003, 06:57 AM   #4
skyhawk1
skyhawk1's Avatar
IMO you need a better ground on the front park lights. I had the same problem. I used a short piece of wire and a couple of stake-ons and ran a ground wire from one of the bolts that holds the park light in place over to the radiator support. Havn't had any problems since.
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 03-19-2003, 07:11 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
Check your floor mounted dimmer switch. They tend t get wet a corrode and cause all sorts of dash related electrical problems. Clean up the mounting area on the floor for it and replace it if it is looking ropey.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-19-2003, 09:09 AM   #6
Blue Beard
Blue Beard's Avatar
You've got a ground problem for sure......mine was doing the same thing, left turn signal.
After a total run down of the entire system, under the dash and the hood. finally found the positive cable was almost burnt in half......
Good luck, tracing these are hard work.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-19-2003, 10:00 AM   #7
TROYLV
blinker light
check your bulbs. one of the filaments in a bulb is making contact on the park ligh filamentin that bulb. had this happen before.
troy wilson
TROYLV is offline   Reply With Quote
Old 03-19-2003, 12:12 PM   #8
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
I'm sure I will have this problem soon. I noticed the other day that i can see all the wires going to the rear through the vent holes (thanks to the rust fairy) in my rockers. Only a matter of time before some big chunk of something falls off and trys to take the wiring with it.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 03-19-2003, 11:10 PM   #9
krazy_texan
krazy_texan's Avatar
i have the same prob with this but on the right side, i have good grounds but am going to rewire the whole truck soon so i am going to deal with it for the time being and also when i turn on my brights i loose my dash lights, do you guys have that prob?
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-22-2003, 02:03 PM   #10
71Custom10
71Custom10's Avatar
I noticed the other night when I was following somebody that I could see my parking light in their bumper but the blinker wasn't working. I checked the bulb and it looked ok, but I replaced it anyway and the light doesn't satay on anymore.
Thanks,
Andrew
Best Towing Service
Old 03-23-2003, 01:53 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
71Custom hit the nail on the head.
When this happens, the first thing to look at is your turn signal bulbs. This i the way GM used to set them up to inform you there is a bulb burned out.
Old 03-23-2003, 06:06 AM   #12
TROYLV
blinker
i must be invisable on here. duh............. read my post. maybe i'll just let everyone figure out there own problems from here out. if anyone would like to know how this happens, ask and i'll explain it. by the way when you have a turn signal bulb burnt out it will not flash at all at the dash indicater. i can explain this also no gm didn't desiegn this ether, the flasher manufacturer did and it is this way in almost all older cars and trucks.
troy wilson
Old 03-23-2003, 09:09 AM   #13
A.P.
Black 72 Chevy
A.P.'s Avatar
Check your grounds. I had this problem with my right blinker. There wasn't good ground on my front blinker on the bumper.
A.P. is offline   Reply With Quote
Old 03-23-2003, 01:53 PM   #14
Longhorn Man
Troy, i was just adding to your responce. The filaments do not need to be touching in order to cause his. You can remove a bulb all together and it will cause the same fault.
I was unsure that anyone else did this too. Good to know info.
Old 03-23-2003, 05:51 PM   #15
TROYLV
blinker
sorry longhorn, i was to quick to jump. just ain't been a good week. blood sugar is up- got the flu- and some dumb a$$ calls at 1:30 in the morning. wouldn't be so bad, but sincei didn't answer first time she does it 5 more times. finaly get out of bed, expecting maybe one of my family is hurt - i get "is john there"? no john here. might as well stay up now. 2:30- again "is john there"--no its still the wrong number. oh, sorry- yea so am i. i get up early, but thats to early. bad part of being in a 24 hr. town i guess. sorry guy
troy wilson
Old 03-24-2003, 12:00 AM   #16
Longhorn Man
no problem man.
