02-27-2012, 04:56 PM | #51 |
Re: sea foam green paint jobs!
Here is mine.
02-27-2012, 04:58 PM | #52 |
here is another
02-27-2012, 06:07 PM | #53 |
I built it
an update
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
02-27-2012, 06:23 PM | #54 |
The Niner
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-27-2012, 08:43 PM | #55 |
A nice one I spotted at a rod run a few years ago.
08-08-2013, 01:06 PM | #56 |
had to bring this thread back to life. Hopefully more will post pictures of their "Sea Foam" green or paint code 518 trucks.
My truck is in primer, but will be going into the body shop in about a month to be returned to this paint code. Cant wait
71 swb 350/4sp manual 5/7 static drop |
08-08-2013, 02:01 PM | #57 |
They are nice colors. Just remember there are two shades, the 67-69 light green code 503 and the 70-72 medium greeen code 518. The lighter color is really the only one I would consider a "sea foam green" in the classic sense. If you are planning on doing a two-tone the factory secondary colors were 67-68 code 526 (Ditzler 8290)ivory/off-white, 69 code 521 white (Ditzler 8080)and 70-72 521 (Ditzler 2185) white.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-14-2013 at 12:38 PM. |
08-08-2013, 04:13 PM | #58 | ||
"I ain't nobody, dork."
My '72 GMC with a black top. Not 100% sure if it came from the factory or dealer this way... but it's the original medium green paint from 1972 as far as I know.
Gary
08-08-2013, 04:32 PM | #59 |
Gary, Intersting paint scheme, what is the paint code on the SPID?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-08-2013, 06:20 PM | #60 |
Great thread guys. I'm looking at redoing my 67 in the 503 /526 color combo. Can you guys break down the 67 light green color code as well as the interior door panels / dash pad etc...
Posted via Mobile Device |
08-08-2013, 06:35 PM | #61 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-08-2013, 06:46 PM | #62 |
A day late and $1 short...
Here is my beater in 503 Light Green ...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
08-08-2013, 06:47 PM | #63 |
Such a Bad @zz truck!
08-08-2013, 07:36 PM | #64 |
The 67 MY factory paint GM code 503 or 533 (as a two-tone) consisted of:
503 Light Green (Ditzler 53523 or Lucite 4728-L) exterior primary body color. 526 Ivory (Ditzler 8290 or Lucite 4195-L) was the two-tone roof color. Please note the roof was painted only to but not including the drip rails in 67. This is unlike later years that extended down the front posts and door frames. There is an example picture below of the correct scheme though not the same color. If you want to look about for matching codes from different paint mfg. this is a good place to start. http://paintref.com/cgi-bin/colorcod...del=ChevyTruck The interior colors for a 503/533 truck consisted of: Argent Silver (Ditzler 8568) glove box door with a textured black insert. Medium Green Poly (Ditzler 43687) This metallic light green is used for the interior sheetmetal (weatherstrip breaks in), doors, door panels, steering column and wheel. The interior seat vinyl is a similar color. Dark Green Poly (Ditzler 43693) upper dash, this is a darker green, flattened paint applied to the dash forward of the dash pad. Basically from the dash slots to the windshield, up to but not including the posts on either side. The dash pad is a similar dark green/turquoise color. For additional information and to buy paint try here. http://tcpglobal.com/autocolorlibrar...FQQJRQodaDA8IA
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-08-2013 at 07:42 PM. |
08-08-2013, 10:02 PM | #65 | |
Thank you sir!!
Thanks Tim. That's great info. Seems the light green stuff is some of the harder parts to come by. Quote:
08-08-2013, 10:13 PM | #66 |
Here are some visors and armrests I have waiting for when I redo my interior.
08-09-2013, 08:49 AM | #67 |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-09-2013, 10:37 AM | #68 | |||
Gary
08-11-2013, 09:46 AM | #69 |
Ttt
08-14-2013, 11:43 AM | #70 | ||
For SS Tim... Here is a pic of the SPID. Looks like it came from the factory with code 548 "White/Medium Green" paint. I know there were some dealer options for black tops, but not sure where this would even be documented. If the PO did it... they didn't do a bad job. The glove box door is also painted black, and there appears to be overspray on the SPID as well. But not sure if it had a black door from factory.
[IMG][/IMG] Gary
08-14-2013, 12:28 PM | #71 |
Thanks Gary,
In your case here the black roof was done post factory as you noted. The black roofs, dealer installed, that I know of were the faux vinyl top look. The glove box door would have been factory black in keeping with GMC's custom of painting the cluster and glove box to complement the interior.
08-14-2013, 04:35 PM | #72 | ||
As always... thanks for your knowledge Tim!
Gary
08-14-2013, 05:05 PM | #73 |
Here is a ad with a textured roof. Look hard and you can see the fake seam tapes. They are about where the windshield header weld joints are.
08-14-2013, 11:47 PM | #74 | ||
Wow... that's a different look altogether. I like my painted black top better than the faux vinyl look.
Gary
08-16-2013, 09:09 AM | #75 |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
