04-05-2018, 06:55 AM | #1 |
frame boxing
Hi gang,
Is there any issue with recessing the added plate when boxing a frame? I'm considering insetting the plate an inch or so for clearance of brake and fuel lines and wiring. I'm planning to use 3/16" with 2" dimple dies. Thanks, steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
04-05-2018, 09:53 AM | #2 |
Re: frame boxing
Wouldn't think so, that's exactly how I would it.
04-05-2018, 11:03 AM | #3 |
Re: frame boxing
I agree, it also gives you room for a nice fillet weld.
04-05-2018, 11:05 AM | #4 |
Re: frame boxing
wouldn't think so....and itll give a nice little ledge to weld on...
04-05-2018, 11:44 AM | #5 |
Re: frame boxing
Lot of work boxing in a frame correctly. Keeping it straight and putting in a lot of bolt sleeves.
04-06-2018, 07:50 AM | #6 | |
Re: frame boxing
Since I'm adding a flatbed, I was recently told boxing the rear end isn't necessary but I question that. What are your thoughts?
04-06-2018, 09:00 AM | #7 |
Re: frame boxing
I don't think it is necessary to use 3/16, that adds a lot of weight.
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
04-06-2018, 03:16 PM | #8 |
Re: frame boxing
Ok, I could do 1/8th inch and larger dimple dies?
04-06-2018, 06:07 PM | #9 |
Re: frame boxing
Even 1/8 is overkill. I'd consider 14 ga.
04-06-2018, 07:35 PM | #10 |
Re: frame boxing
[Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's ]
im assuming this ^^^^is why your wanting to box the frame?
04-07-2018, 10:05 AM | #11 |
Re: frame boxing
No, I'm starting a late '80's square body 4 door diesel project that will be getting boxed and a 12V.
