Old 04-15-2003, 10:32 AM   #1
landon4421
Life is Good !
landon4421's Avatar
electrical question / help
So here is the problum. I started out with a left turn signal that did not work, and the dash lights that would not work. I stated to look around at all the bulbs. they were fine. The I looked at the fuses, the only one that was blown was the one for the dash lights. So I went and replaced it, this is were it gets fun. "POP" the fuse blows out. So I was looking around here and some one suggested to ground the dash, so I did that, but when I pulled the dash out to look at it the printed circut was a little messed up. So I figured fix it. Got the new one and put it on the dash. Now that eveything is put back togeather, I am still having the same problum as be for. the driverside blinker dosn't work, the dash lights still don't work, and now the fuel gauge dose not work. I would like to drive the truck off a cliff, but that would make the wife mad.
So here I am again asking for some help please.
The driver side blinker dose not work,
The dash lights dose not work,
The fuel gauge dose not work,
All the bulbs are good, could not find any damaged wires.
NOTE: where the wire plugs into the harness for the fuel tank sending unit, dose that plug show power when you put a tester on it? If so mine has no power runing to it.
hopefully someone can help if not I will be looking for that cliff
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 04-15-2003, 12:46 PM   #2
cdowns
cdowns's Avatar
well if you're popping fuses that means you have a short circuit: places to check would be :theharness ror the rear lights that runs along the drivers side frame rail, second would be the wiring to the dimmer switch, third the wiring under the chrome step plate by the drivers side rocker panel, you must also make sure you have good grounds all the way around the truck because a bad ground will also blow fuses
Old 04-15-2003, 12:55 PM   #3
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Check your grounds. If you have check them again. Grounds are so important and they can be so annoying to fix.
HotROd
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 04-15-2003, 02:32 PM   #4
Blue Beard
Blue Beard's Avatar
Similar problem turned out to be the positive cable grounding out on the block.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-15-2003, 03:59 PM   #5
bpmcgee
bpmcgee's Avatar
Landon,
I was having a problem with my guages similar to the one you describe. I also had a short circuit on the circuit board.
Here's the part that may interest you -- I found this while was diagnosing a blown fuse in the front lighting harness!
Turns out there's a little rubber inline fuse socket tucked by the battery. It's got a little 4A fuse in it. Is it possible that you may have blown this?
bpmcgee is offline   Reply With Quote
Old 04-16-2003, 12:11 PM   #6
landon4421
Life is Good !
landon4421's Avatar
anyone else have any ideas?
Old 04-16-2003, 12:53 PM   #7
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
The tail lights, dash lights and dome light are all on the same fuse, I'd definitely be looking at the tail light harness. They have a tendency to rub through on the frame. Also a loose tail light bulb can do this too, but normally they would only do that while driving because the vibration causes it to arc and draw more amps.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-16-2003, 04:22 PM   #8
landon4421
Life is Good !
landon4421's Avatar
OK but no one has answered the question about the fuel sending unit. Dose that plug have power or not?
