Old 03-31-2017, 07:44 PM   #1
sharkskinman
Using Air Shocks WITH Air Bags??
65 C10
Front stock shocks can be used as rear shocks when lowered
But I've been contemplating the idea of using air shocks with the airbag whether having a separate inflation line or possibly reducing the inlet for the air shocks so much that when you air up the airbags it allows air to seep in to the air shocks but it's small enough that it still gives it some sort of dampening property
Or maybe a proportion valve between bag and shock?
Thoughts??
sharkskinman is offline   Reply With Quote
Old 03-31-2017, 08:05 PM   #2
PGSigns
PGSigns's Avatar
Re: Using Air Shocks WITH Air Bags??
Why?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-31-2017, 09:20 PM   #3
sharkskinman
Y not
Old 04-01-2017, 02:56 AM   #4
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
An air shock tied into the bag would not have much benefit in actual dampening force, you already have 'load control' with the bag.
If you ran the air shock separately and in a manner to control rebound(think cantilevered applying an opposite force to the lifting action of the bag) it may be possible but would severely over-complicate your suspension with little net gain over a standard shock.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 04-01-2017, 03:00 AM   #5
sharkskinman
Anyone know of a stock shock that works on lowered c10?
Old 04-01-2017, 03:06 AM   #6
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
It would depend on how you lowered your truck and therefore what lengths you would need.
Finding a shock that fit would be one thing but having the right valving could prove more tricky.
Old 04-02-2017, 07:28 PM   #7
PGSigns
PGSigns's Avatar
It is better to run shock relocators on the back and to buy shock designed for our trucks. That way you get a chock valved for the weight and ratios. I use the Ridetech street performance shocks and they work well.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-02-2017, 10:08 PM   #8
James the III
I don't know why you couldn't use just the shock re-locators and air shocks in the rear.. if the bed will never be loaded..
Many of the airride shock/bag units are just fancy air shocks
James the III is offline   Reply With Quote
Old 04-03-2017, 03:04 AM   #9
andrewmp6
Air shocks should be left in the 70s/80s where they belong.The idea of them was to level out a truck that is towing or hauling.But a shock and its mounts are never designed to be a load point that air shocks become.Today airbags for that work better and i rather have air bags and normal shocks.Look up how to measure shock absorber length and call summit racing they can give you a oem shock that will fit your needs.
Old 04-03-2017, 03:16 AM   #10
sharkskinman
I know how to measure!
So if I call summit they'll tell me stock shock reference or Their shock reference?
I bought a pair for my bug vert and the of mount holes aren't parallel.. The air shock mounts Are
Figured I'd see if I could use them
Old 04-03-2017, 05:24 AM   #11
James the III
oh look todays ridetech shockwaves . looks like fancy smancy air shocks to me..
Old 04-03-2017, 09:57 PM   #12
andrewmp6
The shockwave is a bag over a shock just like a coilover is a spring over a shock.The shockwave the air bag is the spring while the shock is just a shock.
Old 04-04-2017, 07:16 AM   #13
James the III
and an old air shock was ??
Old 04-04-2017, 03:28 PM   #14
Willie Makeit
Willie Makeit's Avatar
nothing like that
Willie Makeit is offline   Reply With Quote
Old 04-05-2017, 02:20 AM   #15
andrewmp6
A air shock is a shock with a small air bladder inside that gives a few inches of adjustment.A shock wave has a lot more height adjustment and travel on it,Think of them more like a coil over strut that most cars run on them today but a air bag not coil spring on it.
