Old 02-20-2010, 04:47 AM   #1
corvette6698512
quick T case question
So I was looking into getting a 2 speed aux for my 2wd truck. Would it be a stupid idea to get a 4x4 transfer case and just run a driveline to the rear, and not the front? I have a muncie sm465 to use as the main trans. Thanks.
corvette6698512 is offline   Reply With Quote
Old 02-20-2010, 09:33 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: quick T case question
check out my thread from yesterday on the np203.
theoretically you could put one in with a mile marker kit and then remove the actuator lever for shifting between 2 and 4wd. it would leave alot of dead weight though, and that is not a light case.....
perhaps you could divorce one and machine up some kinda faceplate and yoke??
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-21-2010, 01:44 AM   #3
OrrieG
OrrieG's Avatar
You might look at some of the companies that use the 203 Hi-lo portion for a doubler on other transfer cases. They might have a adapter that would allow it to be used like you want. It would get rid of most of the 203 weight associated with the chain drive and shaft/gears for the front drive line.
