12-16-2018, 06:22 PM | #1 |
65 fuel system
Hi guys. I need a little guidance. I’ve look but can really find what I need. I need to figure out what fuel tank to use. I can’t afford the boyd stuff. This a low budget swap. Thanks in advance
12-16-2018, 07:24 PM | #2 |
Re: 65 fuel system
Welcome...is this for a LS swap into a 65?...
12-16-2018, 07:51 PM | #3 |
Re: 65 fuel system
Yea sorry. Ls swap into a 65 C10.
12-16-2018, 08:22 PM | #4 |
Re: 65 fuel system
I used Tank INC universal fuel tank which fit almost perfect. I had to grind a wee bit on one side to allow it to drop in. I also used there fuel lines. If i had to do it all over again Tank INC makes a early mustang tank that I think would fit also.
12-16-2018, 08:46 PM | #5 |
Re: 65 fuel system
I just found one from lmc. It sayscan be used for efi. Has anyone on here used that one?
12-17-2018, 10:48 PM | #6 |
Re: 65 fuel system
I used a Boyd's tank. Bought everything from Pro Performance. Get the tank, aeromotive pump, and regulator with hose all at one time. There are other tanks, LMC has one, Brothers offers a tank, CPP, and a few others. That is if you want a rear, under bed tank. I have no clue what is available for OEM location with pump and so forth.
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. |
12-18-2018, 08:39 AM | #7 |
Re: 65 fuel system
Thanks. I think I’m gonna go with rear under bed. It’s looking like I might use lmc kit. A long with walbro 255 inline pump. I think that might be a good low budget set up.
12-18-2018, 06:37 PM | #8 |
Re: 65 fuel system
If you have room under the bed, a Blazer tank (with built in pan) can be had for around $100. Sending unit $80, AC delco fuel pump $40, Corvette filter regulator $50 (if needed). Run some fuel lines and go!
12-18-2018, 07:26 PM | #9 |
Re: 65 fuel system
What yea blazer? And s10 blazer or full size?
