Old 06-14-2002, 12:59 PM   #1
Big_Block
Propane to Gasoline conversion?
Hi, I have just baught a 69 chevy fleetside shortbox pickup it has a 403 Olds in it, but it is currently on propane. I was just wondering how hard it would be to make the coversion to gasoline. And if someone has done it before that knows any shortcuts or anything like that. thanks
Big_Block is offline   Reply With Quote
Old 06-14-2002, 01:26 PM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
BAH why switch to gasoline!!!! propane is a nicer fuel i think and i've been working on converting my vehicle to propane. In the switch you'd need nothing other than a new carb, fuel pump and gas tank. just gotta take off the mixer, evaporator, lines and propane tank.
If you want some good reasons to keep that propane setup i can let you know and if you want it gone tell me what parts you've got and what size tank etc etc and maybe we'll be able to work something out.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-14-2002, 01:28 PM   #3
Big69C20 Toy
Livin' it up.
Sorry got a little hotheaded there. Where are you from anyways man? And welcome to THE great board, tons of wonderful folks on here with an array of knowledge. Stick around, you'll like it fine....
-Greg;
Old 06-14-2002, 03:05 PM   #4
tom hand
CCRider
tom hand's Avatar
More than likely they did a simple conversion, which means all you need is a gas tank, fuel pump, and the carb of your choice and you are in buiness. It is possible they raised the compression to take advantage of propanes higher octane, if this is the case the motor would need to come apart for lower compression pistons. You could probably tell by doing a compression test.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-14-2002, 03:22 PM   #5
68 Suburban
68 Suburban's Avatar
Why not have the option to run both?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-14-2002, 04:28 PM   #6
Big69C20 Toy
Livin' it up.
Good point 68, there are simple things for doing a dual fuel and you've already got the propane setup, i think for dual fuel you need a part for the mixer (possibly a new mixer if it cant do it) and a fuel pump, switch and gas tank. For the most part though you should be able to get propane cheaper than gas i'd think and your engine will run longer on it.
-Greg;
Old 06-14-2002, 04:51 PM   #7
68 Suburban
I even have the dual fuel spark control so you can have the engine time properly for both fuels
Old 06-17-2002, 01:45 PM   #8
Big_Block
Well I have come to the conclusion just to by a new motor and tranny with gasoline already on it. I found a good deal on it so I think i am goin to rip the motor out with the propane left on it, so if anyone wants a strong 403 olds with propane settup including the tank lines evapoator ect, and tranny let me know! thanks for the info guys
