06-25-2018, 01:27 PM | #1 |
Blazer Rockers
Do Blazers have an inner rocker panel? Or does the rocker box do that job? My outer rockers are almost gone and I done see any remnants of and inner rocker. Just trying to get an idea of what I'm getting myself into. Oddly, my rocker boxes are in GREAT shape.
'72 K5, known as 'the Fox.' |
06-25-2018, 03:48 PM | #2 |
Re: Blazer Rockers
Yes on the inside of the curved outer rocker is a flat piece that makes a 90* angle with the floor. Search for rocker replacement images and you'll see plenty of images of the guts there.
06-25-2018, 04:55 PM | #3 |
Re: Blazer Rockers
Ok, thanks. I can see straight into the rocker boxes, so they are either missing or rotted out worse than the outer rockers. Anybody sell a THICKE rocker set than OEM or reproduction?
06-25-2018, 05:58 PM | #4 |
Vintage Evil
Re: Blazer Rockers
Let me know if you find any... mine are the thin stuff... i think they get dented when i look at them too hard...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
06-26-2018, 05:50 PM | #5 |
Re: Blazer Rockers
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
06-28-2018, 10:28 AM | #6 |
Re: Blazer Rockers
wow. That's a big deal. Are the clecos just to hold it or are you going to rivet it in?
06-28-2018, 10:32 AM | #7 |
Re: Blazer Rockers
I welded mine, that's how the factory did it.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
06-28-2018, 08:28 PM | #8 |
Re: Blazer Rockers
Here is a break away (rusted away actually) view of the blazer side from an old project of mine.
06-29-2018, 08:41 AM | #9 |
Re: Blazer Rockers
thanks for that. looks like I've got some work ahead (x2). I had thought about making an inner rocker out of something thicker to tie the rocker box and floor together, but it looks a bit more intricate than that.
06-30-2018, 08:54 AM | #10 |
Re: Blazer Rockers
The repro panel is a good one. For a Blazer application the rear of the panel will have to be slightly shortened. The panel was designed for a regular pickup cab, but works fine on a Blazer.
06-30-2018, 11:18 AM | #11 |
Re: Blazer Rockers
If I remive the fender and door, will I see the end if the firewall like in your first picture?
06-30-2018, 01:55 PM | #12 |
Re: Blazer Rockers
The fender, inner fender skirt, and door will need to be removed to see the firewall as seen in the supplied photo.
07-03-2018, 09:09 PM | #13 |
Re: Blazer Rockers
When I did the rust repair on that part of my blazer rebuild - I was given a free part to test the fitment with a new aftermarket piece - have a look here at my review. It wasn't that tough.
http://67-72chevytrucks.com/vboard/s...d.php?t=375946 |
07-03-2018, 09:34 PM | #14 |
Re: Blazer Rockers
I'm pretty sure I won't need that part... fingers crossed!
07-05-2018, 01:31 PM | #15 |
Re: Blazer Rockers
Hows your B pillar? Also any rot in the floor pan?
If you have floor pan rot your subframe might also be gone. |
07-05-2018, 06:24 PM | #16 |
Re: Blazer Rockers
Floor is good at the b pillar on both sides. Just rockers and usual adjoing floor
