Old 08-07-2014, 12:57 AM   #26
kvn1011
Kvn1011
kvn1011's Avatar
Re: Kevin's 1972 build thread (slow motion)
http://instagram.com/p/i7qgkcllVY/
kvn1011 is offline   Reply With Quote
Old 08-07-2014, 01:04 AM   #27
Seventy Two
Nice project. Do you happen to remember the part number for your DT tri-y headers?
Seventy Two is offline   Reply With Quote
Old 08-07-2014, 01:12 AM   #28
kvn1011
Kvn1011
kvn1011's Avatar
forgot that i have a YORK 210 also
i need to purchase an air tank
(to do list)
Old 08-07-2014, 01:17 AM   #29
kvn1011
Kvn1011
kvn1011's Avatar
i'd probably be in the paint booth by now
but i got married, and i found this and chloe!!
Old 08-07-2014, 01:20 AM   #30
kvn1011
Kvn1011
kvn1011's Avatar
ok, i think i have posted everything for the most part
this all happened over a 4 year time span
i usually try to get at least one part on each pay period
Old 08-07-2014, 01:34 AM   #31
kvn1011
Kvn1011
kvn1011's Avatar
Thanks!! and yep, i got it from a board vendor for close to 400.00
Part Number: THY-324Y-C
Old 08-09-2014, 01:09 PM   #32
kvn1011
Kvn1011
kvn1011's Avatar
quick trip to O'reillys to get headlight adjustment nuts as the old ones are cracked and brittle i have the headlight adj screws sitting in some PB blaster to knock off that rust
Old 08-20-2014, 01:39 AM   #33
kvn1011
Kvn1011
kvn1011's Avatar
i have a few updates, but no progress, welder came in!! got the handler125Ez by way of amazon from Hobart as a refurbished unit it has a few scratches but that's to be expected!
Old 08-20-2014, 01:49 AM   #34
kvn1011
Kvn1011
kvn1011's Avatar
i also rec'd my impala SS rear brakes
that i ordered from rock auto
i got left and right calipers for $60.00 total
i had no clue that i would get the caliper, brake pads and brackets for the above price.
the down side is that i ordered caliper brackets, at 11.00 each and didnt need to since the calipers came loaded and also came with the brackets
it was very easy to set up a return authorization on the website, but i lost 6 bucks on shipping
but, again i still feel that i got a good deal on those parts
i have already installed captain fabs, SS brackets
i kit that is right up my alley!!
the quality and the price cant be beat!!
Old 11-09-2014, 10:45 AM   #35
zammer
Addicted user
zammer's Avatar
Nice work!
1972 2wd Blazer - 95% completed
2015 Silverado 1500 4wd -z
2008 AERO 9-7X (TBSS cousin) LS2
1970 Jimmy 4wd - future project
zammer is offline   Reply With Quote
Old 01-20-2015, 06:02 PM   #36
kvn1011
Kvn1011
kvn1011's Avatar
thanks Zammer!
next phase is brake and fuel lines!
Old 09-25-2015, 06:17 PM   #37
kvn1011
Kvn1011
kvn1011's Avatar
brake lines completed i'll get pics up shortly
hope to start wiring soon
hopefully this weekend!
Old 09-25-2015, 06:41 PM   #38
kvn1011
Kvn1011
kvn1011's Avatar
i was also able to clean my gas tank with muriatic acid (4.00) at Lowes
and i used por15 tank sealer that i got from Amazon (44.00) if i remember correctly , it came out really nice!!
i still need to get a new fuel float and sending unit.
i have 1/2 inch fuel line
my plan is to drill a hole into the top of the unit and instal my bulkhead complete with the fuel proof nylon gaskets that way my fuel system will be ready for any upgrades that i can think of
i just need to figure out how to install the metal sock/filter onto the half inch line
ok i think that is all that ive done so far
wait, i do have one pic of what i did with my brake booster lol
saw this mod on power-block tv
it was on a 240 and i thought it was cool and borrowed the idea lol
Old 09-25-2015, 06:46 PM   #39
kvn1011
Kvn1011
kvn1011's Avatar
Wink Re: Kevin's 1972 build thread (slow motion)
i thought it was a slick idea
should be a nice test to see how all the connections work lol
im always taking coloring outside the lines
Old 09-25-2015, 06:48 PM   #40
kvn1011
Kvn1011
kvn1011's Avatar
need to order some stainless button head bolts and shave and fill the top mounting bolts from the old booster combo
Old 09-25-2015, 06:50 PM   #41
kvn1011
Kvn1011
kvn1011's Avatar
if only i could find a long enough steel bulkhead an fitting i would have used it as a mounting point for the master
but something of a higher power intervened and prevented that from being possible
Old 09-25-2015, 06:56 PM   #42
kvn1011
Kvn1011
kvn1011's Avatar
ahhh one more thing
i started the fuel line install
but stopped as i need to get the engine between the rails
question
will i be ok with having hardlines from tank to engine?
or will i need to add a flex line or rubber fuel line near the engine
