Old 04-17-2017, 02:33 AM   #1
87Skier
87Skier's Avatar
How much spline engagement do I need?
I'm working on mating a 6L90 to a np205. I have the short 29 spline transfer case input, and the shortest 4wd 6L90 output shaft. After I get done cutting everything to length, I'm probably going to have about 1.5" to 1.75" of engagement of the transmission into the transfer case. I haven't found anything out there whether this will be enough.
The truck won't see a lot of abuse and it won't be a high hp/tq build or anything, so I'm thinking it will be alright.
What do you guys think?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 04-17-2017, 07:09 AM   #2
sweetk30
sweetk30's Avatar
Re: How much spline engagement do I need?
offroad design has a kit for that combo .
and when I checked a 203 input and a 205 input there was basicly 2" of spline on them . so I try and fill it all up the best possible.
I would say if you get 1.75 tho you should be fine . . . but I am no expert in this combo area .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-17-2017, 10:09 AM   #3
obijuan
i dont understand what parts you have. you should be using a coupler if using the 29 spline dodge np205.
Do you have the aftermarket female 29 spline input?
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 04-17-2017, 11:09 AM   #4
kwmech
At the bare minimum you want to be engaged the diameter of the spline. So if the diameter is 1.5 that is your minimum
Old 04-17-2017, 11:51 AM   #5
87Skier
87Skier's Avatar
Sorry for the confusion. The 4wd 6L90 has a 29 spline output shaft, so I believe when you order this kit AdvanceAdapters you get a female 29 spline dodge shaft for the 205.
I am going to try and keep as much splined together as possible, but I do need some clearance. I think it will be very close to 1.75".
Old 04-17-2017, 12:14 PM   #6
obijuan
Call off-road design. I believe their spacer is shorter giving the most engagement possible.
Old 04-17-2017, 02:30 PM   #7
87Skier
87Skier's Avatar
A shorter spacer/adapter makes the problem worse. The shaft is only splined about half way down, and there is only 2 7/8" of splines. Where everything is mounted right now, the transfer case is about 1" from mounting to the transmission.
Shortening the shaft by 1 7/8" means that there isn't room for the 2" of transfer case input shaft, so this will need to shortened as well.
This would be a lot more clear had I taken a few pictures, but I was annoyed that there was so much of a gap, so I took some measurements and called it a day. I can post pictures later this week.
Old 04-17-2017, 09:26 PM   #8
sweetk30
sweetk30's Avatar
http://offroaddesign.com/catalog/NP205%20Parts.htm
part way down this page is there stuff.
Old 04-17-2017, 09:57 PM   #9
'63GENIII
'63GENIII's Avatar
Ok, I gotta ask. What in the heck is a 6L90? Is it the same as an Allison? Are they put in the newer trucks?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-17-2017, 10:21 PM   #10
87Skier
87Skier's Avatar
The 6L90 is a revised version of the 6L80. It is said to have been designed to replace the 4L80 (in form and function), and uses clutch-to-clutch shifting and does away with bands completely. The 80 and 90 share about half their parts. They have the same gear ratios:
1st - 4.027
2nd - 2.364
3rd - 1.532
4th - 1.152
5th - 0.852
6th - 0.667
R - 3.064
Production started around 2005, and are being pretty much replaced by the 8L90. Evidently, you can only get a 6L90 in a 1500 series new truck. All the rest have 8L90's. You can find them in Camaro's, Corvette's, vans, and trucks in both 4wd and 2wd versions mostly between 2006-2016.
These are not Allison transmissions.
They require a CAN bus to operate, so they came behind gen IV ls engine.
The 6L80 uses a 32 spline output that is the same spline as a 4L80.
The 6L90 received a 29 spline for 4wd applications and a 36 spline for 2wd applications.
Old 04-17-2017, 11:08 PM   #11
'63GENIII
'63GENIII's Avatar
1st - 4.027
2nd - 2.364
3rd - 1.532
4th - 1.152
5th - 0.852
6th - 0.667
R - 3.064
Man, .66 OD? Thats pretty tall!
I did read your other thread with Clinebarger on it. Very impressive build. I wouldn't ever even think of doing more than removing the pan to change the fluid. Very cool upgrade!
Chris
'63 k15 long step
