03-28-2009, 01:42 PM | #1 |
1957 GMC 4x4 frame swap???
I have a 57 GMC 100 that I am converting to 4x4. My stock frame is tweaked so I want to swap the body and put it on a later model 4x4 frame. What years and models are the best for this swap? It will be a daily driver, not a crawler. I have heard of people using the full size Blazer(mid 70's?) for this but the wheel base seems much shorter. I'm figuring on putting a flat bed on so it will make it easier. Anyone on here have something like this? Any help is appreciated. Thanks.
03-28-2009, 05:03 PM | #2 |
Re: 1957 GMC 4x4 frame swap???
check out post #177 on this link and ask that guy what he used.
http://67-72chevytrucks.com/vboard/s...d.php?t=313194
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
03-28-2009, 05:31 PM | #3 |
Thanks GRIMSS. I messaged him and another guy. I appreciate your help
03-28-2009, 05:44 PM | #4 |
No problem. Nasty day here so wasting a lot of time on the computer.
03-28-2009, 05:48 PM | #5 |
It's nice here. I'm going to get my ass outside and back to work. Didn't mean to rub it in.
03-28-2009, 06:16 PM | #6 |
Sure don't rub it in. It's only rain, sleet, and snow.
03-29-2009, 08:25 PM | #7 |
Can anyone point me to a thread on this topic? I have been searching but have not found anything with details.
03-29-2009, 10:00 PM | #8 | |
By The Way.. thanks for the link GRIMSS Hey sorry haven't been on here in awhile but as for my truck I used a 76 fullsize 4x4 chevy frame. All I had to do was weld on some frame mounts. I don't know about the s10 frame but some guys use them on two wheel drive models. Hope this helps let me know if you got any other questions.
--Glenn-- http://67-72chevytrucks.com/vboard/s...d.php?t=345975 http://67-72chevytrucks.com/vboard/s...d.php?t=564403 Last edited by 57ToyBox; 03-29-2009 at 10:01 PM. |
03-30-2009, 10:26 PM | #9 | |
Did you get a reply yet from those PMs??
--Glenn-- http://67-72chevytrucks.com/vboard/s...d.php?t=345975 http://67-72chevytrucks.com/vboard/s...d.php?t=564403 |
03-30-2009, 10:36 PM | #10 |
Yes sir! Thanks Diesel. These people on here are great. I really appreciate all the help. I hope to start my own thread when I get my donor truck. I'm hitting craigslist hard! Thanks again
03-30-2009, 11:33 PM | #11 |
How bad is the frame? These old frames have straight side rails and are easy to bolt up the axles to. A lot more work to swap the body on a newer frame since all the new ones dip under the cab and will require some work to get everything to line up. Raised cab mounts and such. We did a 58 and it was pretty easy. 72 Blazer axles and transmission and transfer case. Stock springs 3 or 4 in block in the back from a Ford in the wrecking yard. Steering was the biggest deal and after some thinking we used a Dodge 4x4 bracket on the frame that lays a Saginaw PS box on its side for push/pull steering. We used this instead of the Blazer box. As I remember the Dodge sat closer to the frame so there was no tire rub on right hand turns. Another plus is these old springs are thinner leafs and much more flexy than the newer stuff, plus the bushings are easily replacable and have grease fittings.
03-31-2009, 06:38 AM | #12 |
Mine is a mod of a stock frame. The steering was taken from a Jeep pickup or wagoneer.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
04-03-2009, 10:22 PM | #13 |
my frame is bent enough to warrant something new. I'd be in as much work fixing what I have as it would to fab the body mounts. Plus I would have all the stuff from the donor, steering components, motor, a/c etc hat I want(need) for the build. This route wasn't my 1st idea but it is the one its taken so I'm going with it.
01-28-2017, 12:56 PM | #14 | |
Active Member
