10-01-2014, 08:23 PM | #1 |
V8 in place of 216 with 3 speed and stock rear
I know this has been asked 100 times but I couldn't find exactly what I want to know. If I want to take out my 216 and put a v8 in and keep my 3 spd on the column and factory rear what will I need. I do have a 55-57 bell housing but I was wondering if anyone made a conversion for the dog ears since the crossmember is flat. Also if I run headers can I keep my stock 3 speed linkage. I have access to v8s but no 235 currently and my babbet rod motor is done unless I want to put a small fortune to it.
10-01-2014, 08:43 PM | #2 |
Re: V8 in place of 216 with 3 speed and stock rear
what year truck?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-01-2014, 09:56 PM | #3 |
Sorry 1951
10-04-2014, 03:11 PM | #4 |
Wont the saginaw 4 bolt trans pattern bolt up to a later than 57 bell housing? The 3 sp should have a 2 bolt mount boss under the trans to build from when you run a rear crossmember. A ton of options for the 3 bolt small block side mount .
GOD BLESS AMERICA! |
10-04-2014, 04:35 PM | #5 |
I thought a 51 had insert bearings but not completely fitted. It used small shims on the rod bolts to establish oil clearance. Seems those could be done for a moderate price if you really want to keep it.
