Old 07-12-2017, 05:38 PM   #1
toolboxchev
SBC 350 Valve Cover Gaskets
So lets here it. Who makes the best one???
Some of the performance ones are at most 3/16 inch thick. I would like to have something that is reusable and ethanol resistant.
Looked at the Jegs options and know there is more options out there. I am keeping the stock stamped steel valve covers for now.
Who has had some success? I would love to know!
toolboxchev is offline   Reply With Quote
Old 07-12-2017, 06:56 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: SBC 350 Valve Cover Gaskets
Unless you have fuel in your oil why would you need ethanol resistant VC gaskets?
I have used the Moroso rubber gaskets and like them a lot. They are reuseable and have a steel insert in them.
https://www.summitracing.com/parts/m...make/chevrolet
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-13-2017, 04:52 PM   #3
SilverMiner
SilverMiner's Avatar
I recently tried the Fel-Pro "PermaDryPlus" style, and have been ecstatic how well they have worked even after removing and replacing the stock covers more than once. They definitely are NOT cheap (I paid $30 at my local NAPA) but they worked so well I'm going to buy more for a couple of my other engines. The oil pan version works fantastic as well, so you could say I'm a very happy customer who feels the high price to be worth it.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 07-13-2017, 05:50 PM   #4
ElKotze
ElKotze's Avatar
Fel-Pro PermaDry. Used it on my valve covers, oil pan and rear main. Bone dry for over a year now.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 07-13-2017, 09:38 PM   #5
68gmsee
Active Member
68gmsee's Avatar
For valve covers I use the Fel-Pro cork/rubber ones. Used them for years and have had good luck with them.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-15-2017, 10:24 PM   #6
toolboxchev
Older motor, still runs good yet I know there is blow by on the rings. I just look for the best I can get for this old thing, my belief is a better part leads to longevity.
Old 07-16-2017, 05:54 AM   #7
cadillac_al
Do you have stock heads and valve covers? I know aftermarket heads and valve covers seal better than the rough cast stock heads and moderately flimsy stock valve covers. This thread has given me 2 new options to try and I thought I already tried them all. The no-name rubber valve cover gaskets turn to hard plastic very soon. It sounds like Moroso uses some better rubber.
The last thread I saw like this there was a few recommendations for Mr Gasket Ultra Seal gaskets. They are cork rubber and I was tired of leaks so I RTV'd them on. They don't leak but it would be nice to use a gasket without the RTV.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is online now   Reply With Quote
Old 07-16-2017, 03:44 PM   #8
ElKotze
ElKotze's Avatar
Yup, stock heads and flimsy stock valve covers. I'm a big fan of Fel-Pro products. I used to seal my diff covers with RTV but I hated to clean the covers everytime I took them off, so I tried a Fel-Pro gasket and it works great. But my covers are pretty straight and not dinged up....
Old 07-18-2017, 03:52 PM   #9
toolboxchev
I thank all whom have given their replies, looks like the felpro permadry are the winner so far.
That is the direction I will be heading!
