Old 03-14-2003, 10:18 PM   #1
Mountain Man
Where can I safely put floor jack???
I have a new 3 ton shop floor jack. Where on the front of the truck can I safely lift the truck without bending anything? Where does GM recommend locating the floor jack?
I am going to attempt to change my oil pan, and tranny pan, to some aluminum high capacity units
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 03-14-2003, 10:55 PM   #2
Mountain Man
ttt
Doesn't anyone know where to position a floor jack under the front of the truck to lift it, without bending? Please let me know where I should position the jack.
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 03-14-2003, 10:56 PM   #3
mooneyes
mooneyes's Avatar
i've always jacked under the a-arms or belly pan with no problems
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-14-2003, 10:57 PM   #4
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
I usually put mine under the front crossmember, can't miss it.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 03-14-2003, 11:01 PM   #5
low 84
low 84's Avatar
if your not doing anything with the front supension i would jack up under the lower control arm, just position the cup on the jack under the spring cup on the control arm. you can lift by the frame rail behind the front tires or by the crossmember as well.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-15-2003, 01:46 AM   #6
orange72350
orange72350's Avatar
I work for an aoutomotive shop, and "" The Book"says never to lift under any of the front suspension. Yer supposed 2 always use a franerail. If u lift on the front susp., it sometimes may compress everytihng just a lttile 2 much/ just my 2 cents
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 03-15-2003, 01:49 AM   #7
low 84
low 84's Avatar
i lift em by the cotrol arms everyday, all day. all your doing is putting the weight of the truck on the control arm which is exactly whats happening when its on the ground. it won't compress it anyfurther than its compressed sitting on the ground with no jack. i agree though, "officaily" the frame is the correct by the book lift point
'05 1500 Crew Cab
RIP
Old 03-15-2003, 01:56 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can lift by anything under there except the floor pans, cab mounts, oil pan, or tranny pan.
I guess the drive shaft wouldn't be a good place either.
Old 03-15-2003, 07:02 AM   #9
Project1970
14.1 @ 96MPH
Project1970's Avatar
Front I lift with the crossmember. Man, I love big V8 Chevies...I have yet to see one that didn't have a nice big crossmember there that makes jacking up easy. My girlfriend's Opel, dad's Mercedes, and sister's Saturn are all lacking in that area...so to jack up the front, I've got to go side to side...
In the rear, I lift right from the bottom of the pumpkin and put the jackstands on the axle tubes.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-15-2003, 09:26 AM   #10
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I usually just throw the jack under either pumpkin and lift away......or under the front crossmember on the 2wd........DON'T FORGET THE JACKSTANDS!!!!!............I wouldn't trust a hydraulic jack as far as I could throw it while I'm laying under a vehicle, I've seen too many come down.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-15-2003, 08:55 PM   #11
krazy_texan
krazy_texan's Avatar
front crossmember for sure
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
