Old 04-16-2011, 09:47 AM   #1
Mil-Spec
Mil-Spec's Avatar
4" Lift kit, Wrong U-Bolts
Hey everybody I'm finishing up my "winter" project of installing my Rough Country 4" lift kit.
Front went on like a champ, but when i got to rear axle it would seem they sent undersized U-bolts. The I.D. of the originals measures at approx. 3.5 inches and the ones RC sent measure at 3.25 inches.
Any suggestions as what to do?
Contact RC and see what they'll do? Contact a local spring shop? Throw a ratchet strap on the u-bolt and pull the splay in? (half-kidding)
Anyone else run into this type of issue?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 04-16-2011, 01:34 PM   #2
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: 4" Lift kit, Wrong U-Bolts
Over 1/4", I would assume you should be able to get them around the axletube just fine still. Cover the threads, tap it on the axle, should be able to get the plate on.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 04-16-2011, 03:18 PM   #3
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
They have good customer service from my experience. I'm sure they'll send you replacements. I would not contact a local shop to make some for you. They are VERY expensive here where I live. If I recall, the last time I needed a set of 4 when I did my 14boltFF conversion I paid $95(!)
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 04-16-2011, 05:48 PM   #4
Altec
Getcha Pull
Altec's Avatar
You got bent over.
Spec- Call Rough Country. They'll get you sorted out.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-17-2011, 09:30 AM   #5
TheWhiteElephant
God is good!
Originally Posted by Altec View Post
You got bent over.
Not when it's the only place within a 4 hour driving distance that will do it and I was doing this on a borrowed driveway on a one-day time limit to my daily driver. We all live in different places, altec. No need for the pirate4X4 comments.
Mando
Old 04-22-2011, 10:23 PM   #6
Kabina
Hold one side of the u-bolt with the threads up and smack it off of something solid right on the arch and it should open up for you.
You might need to do it a couple times.
Kabina is offline   Reply With Quote
Old 04-25-2011, 12:30 PM   #7
DavTay
I think that spreading it at the arch might get it around the axle but then good luck getting the threads back thru the spring backing plate (if that what it's called)
If you have the time make then send you the correct U-Bolts.
'72 K-10 SWB Stepside 4" Lift
DavTay is offline   Reply With Quote
Old 04-25-2011, 04:12 PM   #8
OrrieG
OrrieG's Avatar
I have found wood working pipe clamps work good for spreading or tightening up u-bolts. Seem like on mine there was one on each corner that needed some assistance. If the arch diameter matching the axle diameter is the critical part (and length to get required exposed threads when tightening).
