10-20-2013, 11:08 AM | #26 |
Re: Where did you put your gauges?
I'm glad I could help! I modified the backing plate and used it also. You could probably get away with not using one, but it holds things together nicely and I was able to retain the stock turn signals. Here is a pic of the back.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
