11-07-2018, 09:20 PM | #1 |
Cab mount bushings
When installing cab mount bushings can the cab be adjusted or are the bolt holes only a straight shot?
11-07-2018, 09:46 PM | #2 |
Re: Cab mount bushings
There is a small amount of adjustment, you will notice next to the cab bushings there are actually alignment holes through the frame, and in the body. A couple pieces of pipe, or some 1/2" drive socket extensions will help you line the cab and the frame up pretty easy.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
11-08-2018, 10:48 AM | #3 |
Perfect thanks for the help.
