Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-13-2018, 07:47 PM   #1
65truckowner
65truckowner's Avatar
draw on battery
I have a draw on my battery on my 65 c10. When I unhook the alternator it goes away. So I thought something in alternator is bad and took it to repair shop. He said a couple of things were bad and replaced them. Then it did not charge. So I took it back today and he made it a one wire. I still have a slight draw on the battery until I unhook the alternator wire then no draw What am I missing. I have the voltage regulator unhooked as well. The only thing hot at the new fuse block is the brake light fuse with the key off.
65truckowner is offline   Reply With Quote
Old 11-14-2018, 08:05 AM   #2
dennislbrooks
dennislbrooks's Avatar
Re: draw on battery
http://67-72chevytrucks.com/vboard/s...d.php?t=760365
http://67-72chevytrucks.com/vboard/s...d.php?t=764386
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
