10-05-2015, 09:15 PM | #1 |
no brake lights, but the turn signal and tails lights work
Guys,
I lost my brake lights today. The tail lights work. The turn signals work. and they flash. But no brake lights. I have power at my orange wire on going to the brake light switch under the dash. I was under the assumption that if i have turn signals, id have brake lights and vice versa, but evidently not. Any ideas? |
10-05-2015, 09:30 PM | #2 |
Msgt USAF Ret
Re: no brake lights, but the turn signal and tails lights work
Check the white wire from the brake light switch to the half moon connector for power on both sides of the connector. It carries power for the brake lights into the turn signal switch
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-05-2015, 09:53 PM | #3 |
its dark out, but ill try to check.
the turn signals do work. so is there a separate output path for the brake lights vs turn signals? |
10-05-2015, 11:52 PM | #4 |
check your hazard switch if you have one, it may be half way on or off.
10-06-2015, 08:30 AM | #5 | |
Msgt USAF Ret
Don't forget to press the brake for the white wire power test.
10-06-2015, 10:44 AM | #6 |
ok, i think I at least diagnosed the problem
I do get 12V at white wire when brakes are pressed. I do get flashing voltage (12V, then 0, then 12) on green and yellow (and blue and light blue) when i use the turn signal. green/yellow wires are rear taillights, blue/light blue are front blinker lights. I do get same voltage when the hazzard is turned on. But, I dont get voltage on the green or yellow wire when just the brakes are pressed and no turn signal So, Im going to pull the steering wheel and see what i can see on the mechanics of the switch. Just curious if you know this one: Ive got a tilt column from an 80s motorhome. its got the flat connector (and theres an adapter to take the flat connector to horseshoe) and it has a black hazzard push/pull lever. If i need to replace the turn signal switch, can i use the "correct" one for a 71 C10 with tilt? Or do i have to go get the motor home one? I would imagine i could handle the wiring, but its the hazzard button im not sure of. Any ideas? thanks guys!! youve been a huge help!!! |
10-06-2015, 01:15 PM | #7 |
Msgt USAF Ret
With different columns you are most likely going to have to use the one that's installed.
If you check the part no.s and they match, the same switch should fit both.
10-06-2015, 02:13 PM | #8 |
well, i was able to pull the wheel and study the switch. i love that kind of ingenuity
i disassembled the switch, cleaned the contacts, reassembled the switch, but didnt reinstall. and thought for sure, ill have brakes. nope... looks like i have a break in the white wire. i measure 12V on both sides of the connector, but i dont get 12V up at the contact on the switch. I might need a couple of new terminals. Do you guys happen to know the part number for those terminals that fit the horse shoe and the flat->horseshoe adapter? thanks |
12-23-2017, 06:41 PM | #9 |
Jks, ever get this issue solved? Bad ground?
Thread Tools | |
Display Modes | |
