08-02-2017, 04:09 PM | #76 | |
Re: 283 and a Slight Hop Up
The dual plane Edelbrock Performer is a 2101, which I was thinking was comparable to the Offy 360, you mentioned. The cast iron 327 I have laying around is a 3783244. (62'-63' 327) I believe the Edelbrock carb I have is a 1405/6 (600 cfm). I need to look at it again to make sure it's not a 1404 (500 cfm) carb. I'm concerned the 1405/6 might be too much.
scootermcrad.blogspot.com |
08-02-2017, 05:04 PM | #77 |
Scooter, see how much interest a little old 283 has generated here. I bet if the thread was "350 and a Slight Hop Up" we wouldn't be at 4 pages already! I don't know if you already have a performer intake on your shelf or not, but I use the Performer EPS on my 283. It's made for a square bore carb and now you can get it with the oil fill tube provision too. I like mine and I simply painted it to match my block to keep a more stockish look. My cam is the economical Summit 1102 style grind....it seem to work well. I know people say it's outdated now, but I prefer to call it "tried and true". I did Google the cams The Captain mentioned and I was intrigued. Since I'm by know means a cam expert, (and he seems to know his stuff) I wonder if he could elaborate a bit more on them as now he's got my curiosity up too....Captain?
08-02-2017, 05:38 PM | #78 |
I have been thinking of using a 1102 and new valve springs as well. Engine has good compression and oil pressure so I figured I real have nothing to lose
08-03-2017, 12:05 AM | #79 | |
60-66 Nut
My recommending of one of those two cams was mainly in response to the recommendation of the GM cam by another member. A lot of guys that like the 283's seem to like everything old school and that's fine. It is my experience that a lot has happened in cam grinding technology in the past 50 years. For nearly the same price as the GM cam alone, a guy could buy the XE256H cam AND lifters and get a better cam to boot. That cam may not be the optimum cam for the OP's 283, but it would be better than the GM cam IMO. I have never built a 283, so I can not speak from that experience as others that have posted in this thread.
08-03-2017, 06:28 AM | #80 | |
Yeah, the manifold I have, 2102 (http://www.edelbrock.com/automotive/...ds/sb/2101.jpg) also is setup to run the fill tube, I just have to mill a hole for in the boss. They just leave the boss "blank" to give you the option for the tube. I'm sure it's very similar to yours. It will be cleaned up and painted as well. Some seriously interesting cam discussions here! It's really appreciated. My knowledge is VERY limited. I've built a 350, which had many more goodies, so I've washed it out of my mind completely and haven't been thinking "well, in my 350 I did..." Treating this as a whole different animal. I'm intrigued for sure. So speaking generically, what is it in a cam that I want to look for to maintain some bottom end? More lobe separation? More/less duration? Obviously we know what lift does. It's interesting to hear the term, "more modern grind". Is that based on taste and trends or is that actually related to what we've learned about making power? I have a clean slate here, folks. Pistons will be replaced for the cleanup bore (turns out they are actually 10 over already!). My machinist guy looked at it yesterday and says we will more than likely be going out to 30 over std. Heads are being looked at right now. He's going to rate the stock springs that are in there and keep them if they're good, but if we feel like it's worth it to grab a pack of springs to compliment the cam choice, now's the time to get this done. Going to read back through the cam suggestions, but I still don't feel like I know how to make an educated decision between them. They all look great, to me. HA! I just want to make sure I'm not losing too much bottom end.
08-03-2017, 06:32 AM | #81 | |
THANKS AGAIN!
08-03-2017, 07:36 AM | #82 |
Chatting with the Summit tech they are also recommending the K000032
https://www.summitracing.com/parts/sum-k00032 Thoughts?
08-03-2017, 08:20 AM | #83 |
Just to review, since this thread is not just for me, here are the cam options on the table: (using Summit links just to be consistent. Jegs probably sells the non-Summit brands as well)
GM 3896962 (.450int/.460ex 222/222 dur) https://www.summitracing.com/parts/nal-3896962 Comp Cam CL12-234-2 (.447 int/.445 ex 256/268 dur) https://www.summitracing.com/parts/cca-cl12-234-2 Comp Cam CL12-238-2 (.462 int/.469 ex 262/270 dur) https://www.summitracing.com/parts/cca-cl12-238-2 SUM 1101 (.398 int/.421 ex 270/278 dur) https://www.summitracing.com/parts/sum-k1101 SUM 1102 (.421 int/.427 ex 278/288 dur) https://www.summitracing.com/parts/sum-k1102 SUM 00032 (.427 int/.444 ex 260/260 dur) https://www.summitracing.com/parts/sum-k00032 Did I miss any?
08-03-2017, 09:55 PM | #84 |
I don't remember what trans you're gonna run but if you don't want any lope at idle the old 300hp cam is a good choice, GM run that cam in a lot of 283 / 327 engines.
I THINK the 151 cam was the old 30-30 cam with a hyd profile ground on it, but don't remember for sure. Good luck & have fun! |
08-04-2017, 07:09 AM | #85 | |
I would love for this thing to be lopey at ides, but it seems the bumpier it sounds the less bottom end I'm giving up... or did I miss the boat on this?
08-04-2017, 07:52 AM | #86 | |
08-04-2017, 07:54 AM | #87 |
How do we feel about this cam for 283 bottom end torque?
08-04-2017, 08:02 AM | #88 |
08-04-2017, 08:26 AM | #89 |
found this on another forum hope that is allowed for posting here.
http://www.hotrodders.com/forum/how-...ce-150095.html around post 8 or 9 might give you a little advice as to what works |
08-04-2017, 10:23 AM | #90 |
Im pretty sure you meant lopier cams give up more bottom end...My cam has a slight lope. There's some youtubes of Edelbrock performer cams (pretty much the same) in lots of cars, but I didn't find one specific to a 283. (Also didn't have much time to search).
08-04-2017, 10:29 AM | #91 |
Yes! That's what I meant.
08-04-2017, 10:30 AM | #92 |
Thank you sir!
08-05-2017, 12:27 AM | #93 |
60-66 Nut
The RPM ranges given for most small block cams are based on a 350 cu in engine. Installing a given cam in a 283 is going to move the RPM range up likely 400 RPM if not more. So with the RPM range of the EX262 being 1300-5,600 in a 350, it will be about 1,700-6,000 in a 283.
IMO the XE256 would be the better of the two cams I recommended. I can not find a good example of a XE256 on youtube. However this video of the XE262 in a 307 should be close to what the XE256 would be in a 283. https://www.youtube.com/watch?v=tWyjDNk8dfo
08-05-2017, 04:55 AM | #94 |
FWIW I rebuilt my 283 last summer and did the following. Bored 030 over with flat top pistons, Edelbrock 2102 cam, performer intake and 500 carburetor. I used 416 casting 305 heads and the stock points distributor. Transmission is the factory powerglide with a 3:73 rearend. Performance is a little sluggish at a stop sign because of the powerglide but the thing really comes to life at about 2500 rpm and it flat screams to 5000. Swapping the glide out for a TH2004r would probably do more to improve performance than anything else. I'm happy with my results.
08-05-2017, 05:56 PM | #95 | |
08-05-2017, 10:46 PM | #96 |
Nothing fancy. Dual turbos turned out in front of the wheels.
08-07-2017, 07:05 AM | #97 | |
08-07-2017, 07:16 AM | #98 | |
09-19-2017, 11:15 PM | #99 |
Did you use this cam? If so how is it? You can't just leave us hanging out here you know.
09-20-2017, 07:40 AM | #100 | |
Things are moving slowly, but moving. After some serious debate and reading, himming, hawing, so on and so forth, I decided to go with the Comp Cam XE256 and I bought it as a kit form Summit. Was also quite a bit cheaper through Summit compared to buying direct from Comp Cams. I've sized an appropriate converter to go with it for the 200-4R. In reality, I'll be right on the edge of it being "too much", but for 90% of what I'll do with the truck, I think it will be just right. Right now, the heads are off to be gone through and I'm getting the bottom end ready to go out as well. The gentleman I'm working with does incredible work and is making me a great deal, so I'm just being patient and letting him do his magic. I'll say this... I'm super excited about this little 283! It's nothing really exciting, but it's just been a long time since I've been able to build another motor, even if it is just a little one. The engine has a bit of history, as well, which makes it special. So it's nice it will be carried on as the heart of my little C10.
