08-13-2018, 08:20 AM | #1 |
350 cylinder head dilemma, rebuild or replace?
Hi everyone, the original 350 engine in my 72 c20 is going to need an overhaul and I'm gonna do it this winter. I'm just going to do a basic hone, ring, and bearing on the block. But I'm not sure what to do with my heads. I have at least one burnt exhuast valve, so at a minimum, I would get the heads decked, valve job, and new guides.
But I'm debating on whether or not to put money in the old heads, or just buy new heads. Such as the summit racing house brand heads, which I believe are made by world products. https://www.summitracing.com/parts/sum-152123 Or I could buy vortec heads which flow a lot better than the summit hrads, but then I would also need a new intake (edelbrock 2116), an electric choke conversion, and center to perimiter bolt valve cover adapters. What are your thoughts? Or any head choices I should look at? As far as my goals, I'm not looking to build a ton of power, I just want to wake up the old 350. for example, when I rebuild, I'm going to use the melling mtc1 cam.
2012 GMC 2500hd/ 6.0 1972 Chevrolet c20 350/350 1986 Chevrolet Monte Carlo SS/ 6.0 lsx |
08-13-2018, 10:27 AM | #2 |
Re: 350 cylinder head dilemma, rebuild or replace?
I think you would be money ahead just getting the ones you listed. It all comes down to how much $ you want to spend, but isn't that always the case?
08-13-2018, 11:17 AM | #3 | |
I had different constraints on my project (period correct 1970 Corvette heads), but I was so tempted by the deal on the Summit heads. I wound up spending $1500, where I could have had the Summit ones delivered to my doorstep for less than half the price.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
08-13-2018, 11:40 AM | #4 |
Active Member
If your engine is high mileage (on these engines anything above 100K) I'd consider reworking the bottom also. I did the same on the engine of my 69 with about 120K and because of the increased compression it developed slight knocking while idling. Still ran okay except for the annoying knocking.
I guess it depends on how much work and $'s you want to put in it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
08-13-2018, 12:04 PM | #5 |
Keep an eye out on Craigslist. Picked up a set of rebuilt heads for $250 for the pair.
Vortec seems like a good bang for the buck upgrade. Especially if you can hit up a junkyard and grab the heads, valve covers, assorted hardware. Might not even need a rebuild.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
08-13-2018, 12:13 PM | #6 | |
08-13-2018, 02:59 PM | #7 | |
Active Member
Btw: I was generous when I said over 100K because I agree that a lot of this vintage engines were pretty well worn at above 70K.
08-13-2018, 08:47 PM | #8 |
My truck isn't much to look at but I was always proud of the fact that it was 99% original. Finally after about 10 or 12 years of driving the motor just couldn't do it any more. I was thinking of rebuilding it to back to factory specs but after spending a bunch of money rebuilding another motor that didn't turn out so good I decided on a GM vortec crate motor. I think it was one of the best decisions I ever made.
I still got the look of the old style 350 but with all the up to date stuff like vortec heads, roller cam, one piece rear main seal in motor that should run 250,000 without any problems. For around $2000 you can't beat it. |
08-14-2018, 12:19 AM | #9 | |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-14-2018, 01:02 PM | #10 | |
And I agree, the L-31r (350 vortec) is the best deal going as far as crate engines go. If I need a new engine, it will either be that one, or the old standby 260hp goodwrench 350.
