Old 04-24-2017, 10:08 PM   #1
Port&PolishMan
Port&PolishMan's Avatar
Hey All - Suspension Mod Question - 1 Ton
1 Ton Dual 3800 Chevy 1954
I Believe it to be Mostly Stock - has Helps as it has a Hoist
Previous Owner says He had 4000 lbs in a few time .
I Think 3000 lbs would be Plenty , No sense Breaking or Bending something.
I have only done Bolt on Tweaks
Bushings , Anti-Drive Offsets etc. , Sway Bars for Handing etc.
Looking at the Weight of a 1 Ton Set Up = Huge Weight to Control , So ?
Thinking of Dropping Out the Helper Springs - each side 26 lbs .
Currently No Shocks on this Axle - Considering - Variable Spring Assisted
Shocks HD Approx. 375-500 lbs Spring Rating Each ..as they Vary .
Hoping those would Replace the Helpers & Gain better Ride Control all
at the same Timer ..
Helpers Currently don't Start to get engaged unless You have 1600 lbs Load .
Spring Assisted Shocks x 2 750 lbs - 1000 Lbs - looking for Strong Mounts ( ? )
Input on Spring Assisted Shocks ?
Looking for any Info or Others that may have taken Out the Helper Springs ( I Know I would have to get New Shorter U-Bolts )
Any Idea's or Input Thanks
Dan
Port&PolishMan is offline   Reply With Quote
Old 04-26-2017, 08:19 AM   #2
Port&PolishMan
Re: Hey All - Suspension Mod Question - 1 Ton
No One Altered a 1 Ton rear Suspension ?
In anyway , shape or Form ?
Old 04-26-2017, 12:07 PM   #3
cg285
i don't understand what you are trying to convey.
what is an anti-drive?
what is the timer?
cg285 is offline   Reply With Quote
Old 04-26-2017, 12:58 PM   #4
DieselSJ
Airbags. I'm talking to my local spring guy to come up with a set for my R30 dually that will ride better, then make up the weight carrying capacity with a set of airbags. That should improve ride when empty yet still handle heavy loads. I had 2600lbs in the bed once and it sat level.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-27-2017, 08:30 AM   #5
Port&PolishMan
I heard Air Bags will help on Ride & Hauling are You able to Keeps those with Just a Canister or do You
also Must Run Pump ?
Thinking of removing the 54 lbs of Helpers
Then adding Spring Assisted Shocks _ so I'd gain back 28 lbs ..
I believe it would only Cost about $150.00 to Convert and Gain some Axle Control .. all at the same Time .. , but I'm an Old Timer - LOL
https://www.carid.com/monroe/sensa-t...mpn-58510.html
My Immediate Issue is vehicle vibration Huge Vibration - comes up through - Chassis , Cab Doors , and
Entire Vehicle . Builds from 44 Mph to 52 Where is Gets Insane - then - Gradually gets less to 56 Mph and Gone @ 60 Mph !
1. I have done the Clutch in and Clutch Out , in Neutral , in Gear standing still - Don't find anything .
2. Tires I have 1 Tire & Rim that will be Exchanging out , but this can't be the Booming Vib that going on ..
3. Vib just seems to Heavy - so - I'm Wondering what does a Brake Drum Out of Balance be like ?_?
4. I Ran Dial Indicators all over the Driveshafts & Joint Flanges .. etc. all seem to be good ..
5. I used Infra Red - Gauge - Digital - CHECKING TEMPS - seeing If anything was Higher or Lower then all the Rest Area's ..
( 1 Brake Drum and Tire ) 28 Degrees High then the Rest .. That doesn't seem Like a Bearing - Brake Shoe on that side drags just a little and same Area - where Current Tire with Issues Is .. Just don't Feel this 44Mph to 56 Mph has anything to do with a Booming Vibration - that Feels like It would Shake Your Dentures Out - If I had them .. ( Any Thoughts )
6. When I Mentioned Temperature - After 2 Hour Ride and Hauling 3000 Lbs of River Bottom Top Soil , on a Hot Day 82 Degrees.
My Axle and Rear Brake Drums where 114- 118 on Axle , 125 -137 on Rear End , Brake Drums - with in 2 min. of Stopping
After this Haul - coming in Warm Stopped and Read . Hottest Spot on Brake Drums 148 Degrees - 137 Degree ..
Fronts were all Cooler .. --- so --- Once I remove that 1 Tire and put on straighter Rim - Pretty sure those Temps will Even Up .
I Thought for sure I going to Find Axle Bearing reading 255-285 Degree , But Nothing even Close ..
Only Other Thing I able to think of is ( Back Lash ) way to Far out ?_? - Feels to Me it's Coming from the Rear of Vehicle .
Old 05-01-2017, 09:13 PM   #6
Port&PolishMan
Up Date _ Looks Like Drive_Line Angles are Off !
Current Engine is pretty much all Hard Mounted = No Adjustments .
Hard Mounted everything . .
LOOKING TO MOD THE ENGINE & TRANSMISSION - Angles . . ?
Here the Issue Eng & Trans need to be Tilted Back more . .
Currently 4.57 Degrees on First Driveshaft .
Second Driveshaft 2.99 Degrees
Plus the Eaton is approx 2.75 in Staggered Off Center like most are .
Motor & Trans are on Center Line . ( NOT 3 Degree's ) - Toward the Rear Axle Eaton . .
