Old 01-12-2020, 09:29 PM   #1
norv struckman
95 Yukon 350 TBI flooding
Yukon (v8 automatic) likes to stall on deceleration a lately has escalated to serious flooding issue. Smoged last month and tech said that “cat” was on it’s way out. Fresh plugs and wires plus ran sea foam in tank and down TBI. Also Techron thru the tank. Advise, thanks, norv.
norv struckman is offline   Reply With Quote
Old 01-12-2020, 10:54 PM   #2
ChevyTech
Re: 95 Yukon 350 TBI flooding
The most common problem that causes flooding is the coolant temp sensor.
Check out the testing info in my posts in these two threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=379142
http://67-72chevytrucks.com/vboard/s...d.php?t=322811
Old 01-20-2020, 07:09 PM   #3
norv struckman
Old 01-21-2020, 07:45 PM   #4
So that sensor would be a common cause of running rich? I suspect my '95 Suburban is running rich.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling)
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 01-21-2020, 08:23 PM   #5
ChevyTech
Yes
The OBD1 systems are very unlikely to set a coolant sensor code unless the reading is off the end of the possible range.
1995 is still an OBD1
Old 01-22-2020, 03:58 PM   #6
1976gmc20
Never thought about it before, but it makes sense.
It's the EFI equivalent of the choke being stuck closed.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10
1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20
1977 Chevy C-10 Suburban; 1980 Chevy K-10
1989 Chevy K1500; 1991 GMC V1500 Suburban
1976gmc20 is offline   Reply With Quote
Old Yesterday, 09:04 AM   #7
How about backfiring when deccelerating, letting off at hiway speed? I have done nothing yet about the rich fuel and now when I back off, at say 70 or so, it will backfire as if I cut the ignition and cut it back on while in gear. Same thing coasting down a steeper hill. I doubt the spark is cutting out and on, seems like maybe raw gas fumes accumulating, but I really don't know. Any thoughts by someone who knows the system?
Old Yesterday, 03:34 PM   #8
kwmech
Check the vac hose to the MAP sensor. If it is leaking or collapsed it will also create the similar issue
Old Yesterday, 06:06 PM   #9
Great. Simple enough. I'll check that. Now that mine needs service maybe I'll learn something. It's my second 350 TBI truck and the other was the '90 Blazer I bought new and put 190k on before selling. Never skipped a beat!
Old Yesterday, 07:05 PM   #10
ChevyTech
When decelerating several things come into play
As stated, the MAP sensor should send a high vacuum signal the the computer. This leans out the mixture.
The TPS (throttle position sensor) should show the computer that the throttle is closed and if the computer sees this at high speed then the computer should have the IAC (Idle air control) opening as the engine slows down to act like the dash-pot did on old carbureted engines. The P/N (park / neutral) switch must show the transmission is in gear if the vehicle has an automatic transmission for the IAC the aid in deceleration.
So is short here are a few of the possible causes:
Map (Manifold absolute pressure) sensor
TPS (Throttle Positions sensor)
IAC (Idle Air control)
P/N (Park/Neutral) switch
Somebody experienced with a scan tool can start ruling out potential causes in a few minute.
Old Yesterday, 10:27 PM   #11
I'll have to borrow my OBD 1 scan tool back. Thanks for giving me a way to go.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
