Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-30-2019, 07:50 PM   #1
VictoriaHardware
VictoriaHardware's Avatar
WTB Suburban or Panel Roof
I'm in need of a new roof skin- 60-66 Suburban Carryall or C10 Panel. Let me know condition, location, & price. Can pick up within 700 miles of Detroit. Further will probably need to be shipped by truck.
VictoriaHardware is offline   Reply With Quote
Old 10-30-2019, 09:16 PM   #2
shortstep60
Re: WTB Suburban or Panel Roof
I have one need to look and see how good is is will look Friday
shortstep60 is offline   Reply With Quote
Old 11-01-2019, 05:48 PM   #3
shortstep60
The roof is no good
Old 11-01-2019, 11:03 PM   #4
VictoriaHardware
Thanks for checking
Old 11-03-2019, 10:46 AM   #5
VictoriaHardware
I found one on an otherwise rusty Suburban !
Old 01-22-2020, 09:20 AM   #6
64chevycrewcab
Active Member
i have a 4x4 gmc suburban for sale in Mt Pleasant Mi.
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 01-22-2020, 09:41 AM   #7
shortstep60
How much do you want for it?
Old 01-22-2020, 09:45 AM   #8
64chevycrewcab
Active Member
$1500, also comes with this black body with no frame.
NO TITLES
VIN TAGS ARE THERE
Old 01-22-2020, 02:58 PM   #9
Brad54
Brad54's Avatar
I can come up with one, but I'm 770 miles from Detroit
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
Nostalgia Altered drag car with 2x4 FE Ford.
'57 Chevy 2dr 150 wagon gasser
'76 Power Wagon daily driver
'56 Chevy 2dr basket case
'54 Buick Special
'73 Duster on a rotisserie
Hi, my name is Brad, and I have a problem!
Brad54 is offline   Reply With Quote
Old 01-22-2020, 08:34 PM   #10
DPowers
One foot in front of the other
DPowers's Avatar
Did you ever find one VictoriaHardware?
DPowers is offline   Reply With Quote
Old 01-23-2020, 08:14 AM   #11
VictoriaHardware
Found one. Hauled the whole truck home. Cut the skin off the rusty truck. Cut the skin off the good truck. Installed the good roof on the good truck. Primed, hammered, blocked, sealed. Done.
Old 01-23-2020, 10:15 AM   #12
DPowers
DPowers's Avatar
Great. Congrats. Had a lead on one if hadn't.
Old 02-16-2020, 09:42 PM   #13
rustyrodknocker
Did you take any photos? I set out to do this several years ago but I just cut off the whole roof at the pillars and swapped it. Mine had the typical 70's rain roof.
rustyrodknocker is offline   Reply With Quote
Old Yesterday, 02:31 PM   #14
VictoriaHardware
I do have pictures. I cut it off at the pillars but only to use the pillar/roof structure during transportation to the Body Shop. The Body Shop removed the spot welds around the edge (350 of them) and moved the good skin onto my truck. It was glued on; not re-welded in 350 places. That is a gross over-simplification but not nearly as daunting as it sounds. The shop was very experienced and it went surprisingly smooth.
As opposed to replacing the roof from the pillars-up, replacing the skin avoided all possibility of compromising the structure or having alignment issues with the windshield, four doors, or four windows.
The donor roof was not perfect due the fact that it was 50+ years old. It needed minor body work. To do that it had to have all the paint and headliner removed. I chose to use paint stripper because I did not want to introduce ANY new body repairs to the metal from blasting or sanding. It took a couple gallons of stripper and LOTS of steel wool and gloves. The headliner came out with a paint scraper and heat gun, followed by steel wool and mineral spirits. The headliner removal was done over head. In hind sight, the paint & headliner removal were the biggest part of the job and the nastiest phase. Once it was bare steel on both sides, I loaded in on a trailer and delivered it to the Body Shop.
I was nervous about the whole idea of replacing the roof, but it turned out to be the right thing to do. The old roof had rust, hole, and wrinkle issues. That is one BIG piece of sheet metal. Bigger than any quarter panel and bigger than any floor panel. I would like to see the stamping dies that made it.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
