Old 01-21-2020, 08:28 PM   #1
maverickmk
maverickmk's Avatar
Various Questions
I have a few various, simple questions:
1) Anyone know what the red color is for a '69 GMC red interior? Where I can get some of that paint? I need to get some door panels and want to paint them the same red color that mine are.
2) I currently have three-on-the-tree and am thinking of getting a TH350-400. Will there be any interference with the low hump that I currently have?
3) Where can I find the proper electrical connector for the gas gauge that connects at the sending unit?
It's all fun & games until someone tries to divide by zero.
1969 GMC step side
maverickmk is offline   Reply With Quote
Old 01-21-2020, 08:48 PM   #2
Andyking1203
Re: Various Questions
I'd look at lmc or classic parts for the parts your looking for.. as for the low hump, I dont think the auto would cause a problem.
Andyking1203 is offline   Reply With Quote
Old 01-21-2020, 08:53 PM   #3
72 tigger
72 tigger's Avatar
I believe if our trucks had the TH400, they had the high hump ( l think the 400 was only behind a big block)
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 01-21-2020, 09:03 PM   #4
notsolo
notsolo's Avatar
Keep trying various searches for paint codes interior maybe different.
notsolo is offline   Reply With Quote
Old 01-21-2020, 10:05 PM   #5
Mike C
Mike C's Avatar
I have a 69 GMC C2500 with a 4.10 Dana 60 and Turbo 400 with a factory 350 and it has the high hump. I have a 72 Sub C2500 with 4.10 geared HO52 and Turbo 350 behind it's 350. The Sub is a low hump. As a passenger vehicle, the Subs had some different rules though.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-21-2020, 11:40 PM   #6
BigBird05
My 72 has a turbo 350 with a low hump.
BigBird05 is offline   Reply With Quote
Old 01-22-2020, 12:00 AM   #7
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Various Questions
I have a 4L80E in my 71 low hump and it fits fine. I had a 700 R-4 in it before that.
If I'm thinking right the fuel sensor electric connection is the same as a Cigarette Lighter in these trucks.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-22-2020, 09:52 AM   #8
maverickmk
maverickmk's Avatar
That's right. I knew I had seen that plug somewhere before - many moons ago
Thanks for the idea.
1969 GMC step side
Old 01-22-2020, 09:53 AM   #9
maverickmk
maverickmk's Avatar
Nice, that makes life a lot easier for me.
1969 GMC step side
Old 01-22-2020, 09:54 AM   #10
maverickmk
maverickmk's Avatar
It's more of a burgundy color, not a red, red. But not the dark maroon. Make sense?
1969 GMC step side
Old 01-22-2020, 10:46 AM   #11
geezer#99
geezer#99's Avatar
Don’t forget about the fun part!
Removing the stock bellhousing crossmember.
It’s gotta come out. Trans won’t fit otherwise.
Also will need a rear trans mount.
Old 01-22-2020, 11:44 AM   #12
garyd1961
Didn't think a 3 on the tree had a crossmember.
Edit, I see now you said bellhousing crossmember. I thought that was just a bracket on each side but I never converted one to auto either
garyd1961 is offline   Reply With Quote
Old 01-22-2020, 11:48 AM   #13
geezer#99
geezer#99's Avatar
[QUOTE=garyd1961;8664006]Didn't think a 3 on the tree had a crossmember.[/QUOTE
Of course it does!
Gotta have something to hold up the trans and bellhousing.
Old 01-22-2020, 11:48 AM   #14
Andy4639
Orignal Goof member
Andy4639's Avatar
Talking Re: Various Questions
Yes it's up on the front of the transmission though and it's riveted in. You have to remove it to install the Auto. I cut mine off flush with the frame. Never have finished cutting it out though. It's not seen and not in the way so not a big deal to me.
Old 01-22-2020, 02:30 PM   #15
maverickmk
maverickmk's Avatar
One more random question.
The clutch engages at the very end of travel, which way do I adjust the clutch linkage? I think the rod adjustment needs to be moved towards the rear - ?? If you look at the picture (that I ripped off from LocDoc, thanks Doc), the red arrow shows the adjustment point and the blue arrow represents where my adjustment point is currently positioned, hence why I "think" it should be adjusted towards the rear. Or, is my clutch that bad that it will need to be replaced?
I haven't driven it more than from one parking spot to another in the lot, so I really have no idea how good the clutch is (I need to make the brakes actually work before I can test it )
1969 GMC step side
Old 01-22-2020, 11:35 PM   #16
maverickmk
maverickmk's Avatar
I guess I forgot to add the picture
1969 GMC step side
Old 01-23-2020, 11:44 AM   #17
Andy4639
Orignal Goof member
Andy4639's Avatar
The pedal pushes the rod assembly to the rear of the truck. Your pedal should have about 1/2" to 1" of travel before it engages. There about any way. So yes to the answer of your question. Make the rod longer if you want it to engage quicker. Shorten it if you want it to be slower to engage.
Old 01-23-2020, 12:28 PM   #18
maverickmk
maverickmk's Avatar
I want it to engage quicker/sooner, but the adjuster is at the end of the rod towards the front - in essence making it about as long as it can be.
1969 GMC step side
Old 01-23-2020, 06:42 PM   #19
Andy4639
Orignal Goof member
Andy4639's Avatar
Then your pressure plate & clutch maybe worn out and needs replacing.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
