Old 09-06-2012, 01:37 PM   #1
buck nasty
Rear power window fix solved!!!!
If your back tailgate window roles down on your blazer and does not roll up it's most likely your window switch. It's located on driver side tailgate latch. In side the switch is copper contacts that get dirty and corrode. There is no need for a jumper wire or new switch, all you need to do is clean the contacts with small wire brush. First lower tailgate , take screws out of tailgate plate in center of tailgate. Unhook latch controle rod from clip on latch control in center of tailgate on driver side. Second unscrew tailgate latch on driver side and carefully pull latch and switch out of tailgate. Unhook electric pluge from switch and unbolt switch from latch. Third you need a small flat head screwdriver and pry up 4 metal tabs on the switch top. Carefully remove the cove from metal bottem there is a spring and small copper square peice under pressure if the spring is still in contact. Forth you need to clean the 3 half round copper contacts and square copper peice with a small wire brush. Fith check your springs and change if needed. Sixth put some dielectric grease on all copper contacts and putt switch back together and bend tabs back with plyers. Reinstall back in blazer and ride around with window down with confidents that it will roll back up.
buck nasty is offline   Reply With Quote
Old 09-06-2012, 08:31 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Rear power window fix solved!!!!
They sure do give trouble. Thanks for detailing how to fix this.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-07-2012, 12:25 AM   #3
buck nasty
Oh, The switch is called rear power window safty switch. It is so you cant roll the window up with the tail gate down.
Old 09-07-2012, 03:02 AM   #4
zaccaglin
zaccaglin's Avatar
The switch is located in the passenger side latch of my 85 suburban if that helps anyone. Maybe possibly changed in later years? The previous owner of my rig bypassed it and ruined the factory connector. :/
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 09-07-2012, 09:48 AM   #5
kwin
kwin's Avatar
Isn't there a upper limit switch on these?
Keith
kwin is offline   Reply With Quote
Old 09-08-2012, 05:31 PM   #6
buck nasty
Old 09-08-2012, 05:32 PM   #7
buck nasty
Old 09-08-2012, 05:33 PM   #8
buck nasty
