Old 05-14-2017, 05:50 PM   #1
abig84
abig84's Avatar
newb bed side removal question
1952 3800 9ft bed
i thought the bed sides just unbolt from the center supports. i unbolted the front part of the bed no problem, got to the back and the sides are welded to the back part of the bed
it almost looks factory, so did someone weld this or am i just missing something obvious
abig84 is offline   Reply With Quote
Old 05-14-2017, 06:10 PM   #2
mongocanfly
mongocanfly's Avatar
Re: newb bed side removal question
My 55.1 bed is welded ...my 53 bed is bolted
Old 05-14-2017, 06:51 PM   #3
MARTINSR
MARTINSR's Avatar
My 50ish bed was welded the same way. I never welded it back.I cut both sides right at the weld nicely with a cut off wheel on a die grinder and painted the bed apart and bolted back together.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-14-2017, 08:38 PM   #4
_Ogre
_Ogre's Avatar
the tailgate supports were welded because they got the most abuse
shop air compressor timer
Old 05-15-2017, 02:30 PM   #5
abig84
abig84's Avatar
Brian
so you just basically grinded straight through the welds? thats what i was thinking of doing, this is going to be a ugly patina build anyways so if i have to reweld it and spray a little primer or paint on it so be it.
maybe ill just cut right up the middle so i only have to cut once
Old 05-15-2017, 03:12 PM   #6
mongocanfly
Any reason why your gonna cut it apart..?
Old 05-15-2017, 04:18 PM   #7
mr48chev
mr48chev's Avatar
It's hit and miss on them being just bolted or welded. It may have been what plant they came out of. If you are hauling loads on a regular basis it may need to be welded but for a cruiser it should be ok bolted together.
My ongoing truck projects:
Old 05-15-2017, 11:17 PM   #8
abig84
abig84's Avatar
I'm swapping the rear axle and also have to replace a few of the braces going from bed side to bed side and need to run brake lines fuel lines wiring install fuel tank, you guys know the deal pretty much every needs to be done and just figure it would be way easier with the bed out of the way
How heavy you think both bed sides together are? How many people would I need to just lift the entire thing off in one piece?
Since it's a 3800 and looks like a worktruck so I guess it makes sense to have it welded for strength
Old 05-16-2017, 12:36 AM   #9
mongocanfly
Its not so much that the beds heavy as it is bulky..I'd put a person on each corner to make it safe..out in the open I can pick my bed up by myself (not recommended)..if you have a engine puller you can ratchet strap it from each corner and do it by yourself..I've also seen people use 2x4s crossways for lifting
Old 05-16-2017, 01:18 PM   #10
_Ogre
_Ogre's Avatar
about the only thing i didn't disassemble was the 4 bed panels
with the fenders, tailgate and wood off it was easy for me to stand in it's end from the frame
unless you need it apart, don't bother
Old 05-16-2017, 01:50 PM   #11
abig84
abig84's Avatar
that sounds like a plan then. all the wood is gone so i just need to cut the bolts holding it to the frame, im not going to cut it unless for some reason i really have too
