01-01-2018, 08:26 PM | #1 |
`62 engine swap
I just bought a 1962 C10 with a six in it and was wondering if anyone can guide me through the motor mount process for puting in a 350. The truck doesnt have side motor mounts and I dont have a donor truck that had a V8 in it to rob from. The truck has a 4 speed granny transmission. Any Help would be greatly appreciated.
01-01-2018, 08:34 PM | #2 |
Fabricate till you "puke"
Re: `62 engine swap
Talk with Captian Fab on that...he is into the early trucks, & will have good advice, & maybe parts......longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-01-2018, 08:35 PM | #3 |
Re: `62 engine swap
Thank You!
01-01-2018, 08:53 PM | #4 |
Re: `62 engine swap
WOW! I did not see that you just started.....its a good board, with a bunch of info. Welcome to the fun! Longhorn
01-01-2018, 09:03 PM | #5 |
Re: `62 engine swap
Ive been a member for almost 4 years but havent done much with it yet. Now with the new truck it should be an exciting adventure! Thanks again.
01-01-2018, 09:48 PM | #6 |
Re: `62 engine swap
I had a 62 4wd, they used the horse shoe type mount up front. Not sure if 2wd does or not...sorry if not much help lol....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-03-2018, 02:20 PM | #7 |
Re: `62 engine swap
Manual trans 62's with either 6 or 8 used the front mount. Autos did not. The 6cyl 235 used a different bell-housing than the V8 also. You would need a 60-62 V8 bell-housing with hyd clutch set-up + the front Horse-shoe front mount (i think the 6cyl mount is different) You didn't say if changing to an auto trans with the 350? If auto you could use after-market cross-members (under eng and trans or find some stock auto side mounts) It.s not as easy to do this swap on 60-62's as 63-66. Hoped this helped some--good luck.
1961 chevy K10 my build is------------61K10 build |
01-03-2018, 06:41 PM | #8 |
Re: `62 engine swap
01-04-2018, 01:26 PM | #9 | |
Re: `62 engine swap
I am currently doing this with a '60. Found the bellhousing through a member here, Found the front mount on Ebay. Expect to spend 200 - 300 on bellhousing and 100 - 150 on front mount. (Thats when you can find them for sale) Will also need a V8 throttle lever. I do know where there is a '62 parts truck in central Iowa with all the good stuff you would need. Its rough but complete $600 If you can fabricate and not going for the original look might be better off to sidemount it. |
01-04-2018, 04:04 PM | #10 |
Re: `62 engine swap
I'm just ironing out the wrinkles on my '62, put a 383 with a 700r in it. I ended up getting some motor mounts out of, I believe a '71. I had to shim them up a little bit, the frame on a '62 isn't as tall. As far as the 4-speed not sure what you will have to do. I cut the old mounts out where the 3-speed sat.
01-06-2018, 11:40 AM | #11 | |
Re: `62 engine swap
01-06-2018, 11:47 AM | #12 | |
Re: `62 engine swap
Thread Tools | |
Display Modes | |
