Old 06-11-2018, 05:52 PM   #1
ddc456
Active Member
78 Chevy wiring question-Truck won't shut off at the key
Little back story, i had to replace the wiring harness as the prior owners fried the original, i was able to find a clean 78 unmolested harness, everything has been plug and play. My one issue is when i go to shut off the truck at the key it's not killing it. So to killing the truck i have to unplug the lead that is coming off the fuse-able link (the one with the inline fuse see the pic below, obviously it's fused and connected to the fuse block) but it plugs into the "IGN" on the fuse block and it kills the truck i just unplug it. Where should i be looking to resolve the issue?
Doug
ddc456 is offline   Reply With Quote
Old 06-11-2018, 07:29 PM   #2
Goats86
Re: 78 Chevy wiring question-Truck won't shut off at the key
probably the switch itself or the linkage between it and the lock.
Goats86 is offline   Reply With Quote
