04-07-2015, 12:17 AM | #1 |
Replacing Cab Mount Bushings
Today I got under the truck and sprayed the cab mounts with pb blaster and im letting them soak overnight since I'm in no rush. My question is simple. When I go to remove the bolts tomorrow, would it be better to use an impact gun or a ratchet/breaker bar? My main concern is that I don't want to break the captive nut free and have to cut a hole in the cab. Thanks in advance.
04-07-2015, 12:42 AM | #2 |
Re: Replacing Cab Mount Bushings
Always a breaker bar to get them going then a impact especially on something like that.
04-07-2015, 01:07 AM | #3 |
ok, so an impact from the start would be too much torque and higher chance to break the captive nut free?
04-07-2015, 10:56 AM | #4 |
I think you could feel the fastener better with a breaker bar. The impact might rattle through corrosion better, but I also find I that, if need be, I have more grunt with a good breaker bar than an impact.
I soaked my cab mount bolts with Moovit (another un-stickifier) every day for about six months before I pulled mine. Came apart just fine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-07-2015, 11:00 AM | #5 |
A steady amount of force will likely not break something instead of a quick jar. With that being said be warned the bolts can be really rusted as well and shear off... Lots of lube and heat.
05-25-2015, 04:14 PM | #6 |
so i finally got the front driver's side nut loose. i decided to just take it out since i could turn it. while i was turning it, the upper bushing came out. also, it looks like the bolt is coming out at an angle. i have it out quite a few turns but it's not coming out. just for comparison i removed the rear driver's side which came out nice and straight. do i need to lift the cab to straighten the bolt out to lift it, or is there a chance i broke the captive nut?
05-25-2015, 05:02 PM | #7 |
The bolts jam and spin the nuts due to dirt and rust on the threads. Loosen .25 turn, tighten a bit less than .25 turn, repeat to clean the threads.
