09-12-2010, 08:01 AM | #1 |
undercoating
Whats the best way to remove the undercoating on my fire wall I want to paint that area?
09-12-2010, 07:59 PM | #2 |
Re: undercoating
Heat gun and a scraper is what I've been told.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
09-12-2010, 08:19 PM | #3 |
Re: undercoating
I used some odd rolac type discs. They were not the sand typeI used 2 different ones. 1) looks like it has a bunch of fingers sticking out. 2) looks like a piece of scotch bright filled with a wax type material. these worked great. good luck
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
09-12-2010, 09:04 PM | #4 |
Re: undercoating
I like using the 3m paint and rust removers.
http://www.autozone.com/autozone/acc...er=193459_0_0_ http://www.autozone.com/autozone/acc...er=193460_0_0_ The first one would work best for removing the undercoating. You can get them alot cheaper at walmart, usually. I've found they work best in a air powered tool rather than electric.
Chris 52 Chevy 3600 (3/4 ton) 5 window pickup -54 235 Inline 6 w/ Fuel Injection Conversion -Clifford 2/4bbl Aluminum Intake and Headers -1/2 ton front axle swap w/ 5lug disc brake kit -CPP Power Steering Kit Various pictures of my 52 Chevy 3600 Last edited by drummin89; 09-12-2010 at 09:05 PM. |
09-12-2010, 09:38 PM | #5 |
Re: undercoating
kerosene + paint scraper
09-13-2010, 12:02 AM | #6 |
Re: undercoating
Heat and a scraper will be the cleanest. Comes off in chunks, often leaving perfectly clean metal. Key is to SOFTEN the stuff, don't melt it.
