03-02-2018, 10:46 PM | #1 |
remote starter
Is there an easier way to connect a remote starter for bumping engine over. I cannot get to my starter solenoid, big PITA.....sbc 350 59 chevy p-up
03-04-2018, 01:01 AM | #2 |
Msgt USAF Ret
Re: remote starter
You'll probably get more response if you tell us what your problem is and why you want to jump the starter solenoid wire.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-04-2018, 03:03 PM | #3 |
Re: remote starter
thanks for the update, i am tired of breaking my back trying to get to the god-awful location of the solenoid every time i need to set my TIMING... so as i said there has to be an easier way, and thanks to the guys on the hot rodding forum i now have a solution...
03-04-2018, 04:31 PM | #4 |
Re: remote starter
install a remote solenoid on the fender well/firewall and convert your GM starter to a one wire operation, simple to do..
remote start/bump over engine with handheld thumb switch by jumping B+ secondary lug or B+ at the battery to the primary S lug.. this is also popular conversion for folks with headers, eliminates live B+ cable running down there except while cranking.. also pulls the B+ running to vehicle fuse box/distribution panel up from the starter to safer and accessible location in engine compartment.. this is certainly one design aspect advantage f o r d had over GM search 'convert GM starter to remote solenoid' for more info.. good luck! looks something like this;
I started out with nothing - and I still have most of it |
03-04-2018, 04:43 PM | #5 |
Re: remote starter
Wow, great idea thanks for the input.
03-08-2018, 06:49 PM | #6 |
Re: remote starter
You could splice into the purple wire coming throught the firewall above the starter. Or make it a little more presentable by crimping another wire to the purple wire's terminal, again at the firewall connector. You could keep it short or run it over to the right fender well to a junction block stud. That would give you a quick and easy place to clip the remote start alligator clip.
03-08-2018, 07:02 PM | #7 | |
Re: remote starter
