02-22-2020, 11:14 PM | #1 |
Electric fan ? -or- not
What is the benefit of an electric fan over the stock belt driven fan ? A 6.0 in a 1963 GMC is not going to suffer from lack of horse power because of the belt driven fan.
I have a stock belt driven fan, why don’t I just use it ? ..
48 CJ2A 63 1500 GMC (LS1 w/ Muncie 4spd) 68 RS Camaro 71 K20 BBC & granny 4 speed 95 2500 4x4 17 HD2500 4x4 Want => 67 C10 short bed w/ Manual Tranny |
02-23-2020, 12:39 AM | #2 |
Re: Electric fan ? -or- not
wont be any issues...if you have room..the mech fan wouldn't line up with the stock shroud on mine , so I went elec
02-23-2020, 01:12 AM | #3 |
If you've got a shroud that fits properly your belt-driven fan should work fine.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-23-2020, 10:30 AM | #4 |
Electric would be more fuel-efficient. You'll likely never notice, though, particularly if your coming from a 1960's stovebolt-six. Like Mongocanfly mentioned, the main thing is whether your fan and shroud line up well enough to make it work.
I'm going with electric myself. A lot of my trips will be very short. 1/2 to 2 miles. I expect the fans to never even come on during those trips. If I'm driving further, I'll be cruising at highway speeds, and will very seldom sit in traffic. Again, the fans won't come on. I could probably skip the fans, and never miss them 95% of the time.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-23-2020, 02:03 PM | #5 |
Moderator
I agree with using the water pump driven fan if it lines up. Using a proper fitting fan, clutch and fan shroud in my opinion can't be beat. The reason some people use an electric fan are modifications that make it difficult if at all to use a belt driven fan. I've used them in the past because of that same reason.
